Question about Samsung Televison & Video
I have a Samsung smart inverter model no aqv24uwbn. It starts then stops. Two green lights flashing
2 Suggested Answers
  • 1253 Answers
SOURCE: HOW TO RESET A CODE ON A SAMSUNG SMART INVERTER MODEL NO AQV24uwbn?
Unplug it, then plug it back in. Unless you repair the cause of the error code, the unit will fault out every time it sees the error. It is basically saving its own life.
Posted on Feb 23, 2015
My Samsung smart tv has sound but no picture
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jul 25, 2016 | Samsung 5500 Series UN32F5500AF 32" LED...
Samsung smart tv has a black screen that flashes to a real screen for about 1 second then goes back to black. it has sound
http://electro-medical.blogspot.com/
Mar 13, 2016 | Samsung 5500 Series UN32F5500AF 32" LED...
Tv sreen wont turn on
Dec 02, 2015 | Samsung Televison & Video
Samsung 50 Smart TV...Sound but no picture...Fuse? or Inverter? or what?
Look at the picture up close and with a flash light. If you can see images then it is the inverter
Sep 09, 2015 | Samsung Televison & Video
What causes a Samsung dishwasher to flash heavy and smart auto on control panel
Hello. The lights you describe are an error code that means over-level filling (overflow condition) and/or the leakage sensor underneath has detected water. You need to check underneath the unit for any moisture. There is a leakage sensor located at the center of the base, underneath the unit. If it detects water, it will notify the main board which will stop the unit until the condition is cleared.
Aug 02, 2015 | Samsung Dishwashers
How can i fix a black screen with sound on a led smart tv
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Jun 09, 2015 | Samsung 5500 Series UN32F5500AF 32" LED...
Feb 23, 2015 | Samsung Heating & Cooling
Samsung smart inverter AQV12UWAN has green flashing light at the timer and will not operate.
AUTO- DIAGNOSTIC FUNCTION
The unit has an auto diag to detect failures. When an failure is detected , the Lamp will blink.
The manual states:
Before contacting customer call center green number, please ask installer to make a double check of all connections of installation unless there's a full evidence of SAMSUNG product problem.
Oct 24, 2014 | Heating & Cooling
I am working on a Samsung SyncMaster 170MP. When plugged in the green on/off power button light flashes continuously and the screen never comes to life. I've tested the power brick and the outputs (14V @...
It sounds like it since you have the 14v going to the inverter. Repairing inverter boards even on lcd's is 50/50 shot, so let's give it a go. If you have a dvm check the ohms on the inverter xformers ( if more than one) they should be identical in resistance. Check or replace all electrolytic caps on the board. That's about all you can do outside of replacing it, Oh, see if you have a 5v source going to in inv. bd also, check that.
Feb 21, 2009 | Samsung SyncMaster 17 in. LCD Television
Televison & Video Logo
24 people viewed this question
Jerry Greenberg
Jerry Greenberg
