I have this remote to a Iview 3500stbii converter box, wont turn chanell or volume,flashing light only
  • Televison & ... Master
  • 6,694 Answers
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://electro-medical.blogspot.com/
Posted on Dec 29, 2016
2 Suggested Answers
gopakumarg43
  • 75417 Answers
SOURCE: I have a iview converter box remote. 3500STBII. I want to program it to work my Magnavox dvd player
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Posted on Oct 05, 2015
I have a iView 3100STB converter box with broken remote How would I program this into a universal remote? Do I need a specific code?
You have this backwards. The remote control is the source of codes. You can try using code search to find something that works. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
May 02, 2017 | Iview Televison & Video
Oct 04, 2015 | Magnavox Televison & Video
How could I set my I view universal remote to my tv
search the code of the tv then encode it to you remote..every tv has a specific code
Feb 16, 2015 | Iview 3500STBII Multi-Function Digital...
MY BOX KEEPS SAYING BOOT DID i CONNECT SOMETHING WRONG
Antenna cable would go into ANT in
What cable did you use to connect box to tv.
I don't have the user manual so I am guessing that ANT out is for analogue channels 3 and 4 to go through to the tv. think
I suspect the coaxial out would go out to a video in type connection on the television.
If the Television has HDMI inputs I
you should go out and buy a HDMI cable and use HDMI out on the box.
Does the remote control for the box have a plastic strip in the battery compartment that stops the batteries. Or are batteries in the battery compartment.?
Jan 15, 2015 | Iview 3500STBII Multi-Function Digital...
What type of coaxial wire is supposed to come with the 3500STBII multimedia converter box? It didn't come with mine and I am having trouble making it work.
Input coaxial signal needs to be digital only There is a blog on AVS with most info such as firmware updating and what works the best. I have one myself and works well for me. Note: input needs to be digital from outside antenna or receiver giving digital output only.
May 26, 2014 | Iview 3500STBII Multi-Function Digital...
What kind of coaxial wire is supposed to come with the box?
Info on the DVR which I use myself can be found at iView 3500STB Tuner DVR Owners Thread Remember the input needs to be digital not analog. You can not take a signal from a cable box to the input side of the 3500STB as is a anolog signal
Hello, the remote has quit working for the volume
Ur free air DTV converter box have problem taking in the programs codes belong to ur tv,belong to the remote.Turn the converter box off/on to reboot ur DTV converter box.Read ur owner manual,re enter ur tv codes,belong to ur tv.U tv should be up and running again.
Jul 31, 2010 | RCA Televison & Video
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
Hooked up converter box and stations are all working but sound is coming out a hissing.
Use the volume control on the remote for the converter box to raise the sound level. Adjust the TV volume with the converter box turned all the way up then reduce to normal listening level with the converter box remote.
Jul 29, 2009 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
I cannot find the code for my (ilo) brand TV from Wal-Mart and after the scan the scanner does not pick up on a channel I know is there. My friend has the working channel on his digital TV, but it...
try the Funai codes look on the back of your tv and see if Funai made it if so try ther codes. My Magnavox converter box wont pick up chanel 10 here for some reasion says no signal.works ok on all of the other chanels. Now if you have the orginal remote you should be able to go into the menu and go to add/delet and add that chanel to the scan if it has been deleted for some reasion.
Feb 21, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
