Question about New Home Sewing Machines
I'm considering purchasing a New Home Memory Craft 7000. Does it have a feature that adjusts the tension on the pressure foot? Also, does the dog feed go down for quilting?
  • New Home Master
  • 12,273 Answers
Here is the manual for the 7000. Page 28 shows the presser foot pressure adjustment as well as the feed dog drop mechanism:
Janome Memory Craft 7000 Instruction Book Page 29
Hope this helps.
Posted on Dec 29, 2016
The pressure foot pressure is not feeding the fabric. I have adjusted the tension but still not feeding the fabric. What else can I do?
Tension does not affect the ability of the machine to feed fabric, except in extreme cases perhaps when tension is too tight.
You probably need to adjust the presser foot pressure of your machine. Lighter weight fabric is more difficult to feed, therefore the pressure needs to be increased. (Heavy weight fabric will sometimes push the upper layer of fabric in front of the presser foot, therefore less pressure is required.) Even so, very fine slick fabric (silk, satin, chiffon) sometimes still needs additional help. In such cases, a roller foot, teflon foot, or walking foot may be beneficial. There is also the possibility that the feed dog teeth have been worn so they do not grip the fabric like they should. (Avoid running the machine without fabric between the presser foot and feed dogs to protect the feed dogs from unnecessary wear.) If they are worn, usually they can be replaced.
Another possibility is that the feed dogs do not raise as high as they should. This would most likely require a technician's assistance.
Um, as an additional thought, make sure the presser foot surface is smooth. Any rough surface (nicks, rust, etc) will restrict the fabric's ability to move.
Jan 30, 2017 | Sewing Machines
Hi, My Elna 7000 doesn't easily feed medium or thin fabrics. Presser Foot tension lever is position 2 and the Feed Dog is rising normally. Any thoughts please? Does the F Dog wear out in any way?
Generally, the lighter the fabric weight, the heavier the presser foot pressure. Yes, feed dogs do wear with use. Do not run the machine without fabric between the presser foot and the feed dogs--the feed dogs constantly rubbing against the presser foot will quickly wear the feed dog points. Store the machine with the presser foot down with a pad between the presser foot and feed dogs (even a scrap piece of fabric will do). Also, be sure to clean the feed dogs of any gunky build-up. If the feed dog points are worn, it may be worthwhile to have them replaced.
Jan 23, 2017 | Elna Sewing Machines
Why when I sew the fabrics not advance even if the claws are raised and the machine does not stop sewing. I have to close the switch
With the issues you are experiencing, it may be wise to take it for service.
Even though the feed dogs are raised, are they actually moving forward and back as you stitch (remove the thread, raise the presser foot, rotate the handwheel, and watch the feed dog action)? Check that the stitch length is set long enough that the feed dogs will be moving the fabric rather than sewing in place. Another thing to check is whether there is a pressure adjustment for the presser foot. If you are sewing light weight fabric, sometimes the pressure needs to be increased so the feed dogs are able to grab the fabric.
As for the machine running on, it could be a multitude of issues, ie the foot control, electrical... This may be something that a professional should evaluate.
Jun 22, 2016 | Janome Memory Craft 9000 Computerized...
Not feeding material.
Tension generally does not affect the feed unless it is way too tight. Most reasons for fabric not advancing under the presser foot is that the feed dogs have been dropped for darning. If the feed dogs are operating properly, as the handwheel turns the feed dogs should rise above the plate, move toward the back of the machine pulling the fabric, drop down, come forward and rise again.
The other possibility is that the presser foot pressure has been released so the presser foot is not holding the fabric down on the feed dogs. Some machines have a spring-loaded knob on the top of the machine, a dial, or something to adjust the amount of pressure the foot applies. Consult your owner's manual.
Aug 10, 2015 | Sewing Machines
Seems to be too much gap between pressure foot and tension plate .. material is held loosely
Are the feed dogs completely up?
Are the feed dogs worn or clogged with lint and yuck?
Is there a presser foot pressure setting dial or knob?
Is the correct foot on the machine?
Is the presser foot correctly mounted?
Is the needle plate correctly mounted?
Jun 25, 2014 | PfaFF Quilt & Craft Pro 7530
I am trying to set my Memory Craft 4000 machine to do free hand quilting. I have lowered feed dogs and put on the darning foot. when I practice the top looks great but on the underside of the fabric the...
Sounds like you have no tension on the upper thread. Rethread the top thread, make sure you have the pressure foot raised, and have your tension around 5. Don't forget to lower the pressure foot before you began to sew.
May 11, 2011 | Janome Memory Craft 4000 Sewing Machine
How do I adjust tension on my dogfeed?
You haven't said what make and model of machine you have.
Howver, pressure onto the feed dogs is usually controlled by adjusting the pressure foot pressure which is pushing the fabric down onto the feed dogs, you don't usually adjust the feed dogs themselves.
Pressure foot pressure is sometimes a dial or knob on top above the pressure foot area, if there isn't one visible on your machine, then it probably isn't a feature it has.
My Janome has knob on top that you can turn turn or up to tighten or loosen the pressure - I don't usually adjust it much though, only time might be if I'm sewing a couple of layers of vinyl or leather and having trouble getting it to feed.
Mar 25, 2011 | Sewing Machines
Janome 9000
Remove the needleplate and clean out the lint from between the teeth of the feeddogs........it is the most likely reason, the lint holds the feeddogs below where they need to engage fabric.
Check your Presser foot tension is at 3 then do a test.
If this is not sufficient the method of adjusting feeddogs is possible at home, tho perhaps not for those lacking some confidence in mechanical adjustment.......so post back for detail if needed.
Jul 21, 2008 | Janome Memory Craft 9000 Computerized...
Janome 8000 memory craft embroidery/sewing machine
on the backside of your free arm there is a small lever which can be moved to lower the feed dogs.
When you want them back up move the lever the other way.NOTE!!
They will not go up until the machine has made one revolution.
sewman7
Jun 02, 2008 | Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
