Question about HP Envy 4500 e-All-In-One Printer, Copier, Scanner
My HP printer series 4500 only prints 50% of wireless copy. The paper that is printed only feeds out part of the way, then I have to manually pull the rest out of the printer
printech
  • 159 Answers
SOURCE: Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Posted on Mar 16, 2008
SOURCE: hp officejet 6210 won't print
Perform the following steps:
a) Turn the printer on.
b) Open the printer’s top cover.
c) After the print cartridges have moved to the center/home position of the printer, unplug the printer’s power cord from the electrical outlet.
d) Remove the print cartridges.
e) Using a dry, lint-free, clean cloth, wipe the print cartridge contacts, from the top to the bottom
f) The contacts inside the printer may also require cleaning. Using a dry, lint-free, clean cloth, gently wipe the contacts, from the top to the bottom
g) Plug the printer's power cord into the electrical outlet.
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Now, perform the following:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Posted on Apr 01, 2008
APremkumar
  • 564 Answers
SOURCE: Printer offline HP 4500 series wireless.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on Mar 31, 2009
efs_perpends
  • 1996 Answers
SOURCE: HP Photosmart C6280 Will not feed paper correctly
Please onsult this HP support article and follow the steps outlined there to clean the rollers, etc. Frequently this roller cleaning and possibly a reset is all that's required to clear the jam error. (If you have access to compressed air, you can gently blow air throught the printer to clear out paper dust and debris from inside.
Also be sure to follow the instructions in the manual or here to load the paper correctly, fan sheets before loading, and if the problem continues, try flipping the stack of loaded paper upside down and reloading, or try another kind of paper..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 03, 2009
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
I need a print copy of a user manual
[PDF]HP Deskjet 2540 All-in-One series
www.hp.com/ctg/Manual/c03847745.pdf
Hewlett?PackardAdvanced printer management tools (for networked printers) . .... Learn how to useyour HP Deskjet 2540 series. ?. Printer parts on page 4. ? ... Paper-width guide for the input tray. 7 ... Press the Wireless button and the Start Copy Black button from theprinter .... One corresponding cartridge is low on ink and will need.
[PDF]HP ENVY 4500 e-All-in-One series
h10032.www1.hp.com/ctg/Manual/c03784120
Hewlett?PackardThe printer is printing, scanning, copying, or is on and ready to print. ENWW .... You do not need to manually reload the paper or make any operations. ENWW.
[PDF]USER'S GUIDE - Brother
Dec 29, 2015 | Office Equipment & Supplies
I bought Premium Photo Paper and it keeps causing a paper jam and will not allow picture to be printied
probably the paper is heavier than the specification for the printer will allow, different printers handle different g/sm paper
lighter paper may work correctly.. Kughter premium paper is probably available if you check around
Jul 16, 2015 | HP Officejet 4500 Wireless All-in-One...
Where is the duplexer of the HP 4500 Officejet printer?
its located on the backside of the printer behind an access door. You can find a very good video from HP on clearing paper jams at YouTube. Here's the link:
https://youtu.be/lS1441RmrKY
Fixing Paper Jam HP Officejet 4500 Wireless All in One G510n
Jul 08, 2015 | HP Officejet 4500 Wireless All-in-One...
Hp help
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3986399&
Manual
There is a guide for envelopes per manual. Place envelope with printed side facing up.
Good luck
May 05, 2013 | HP Officejet 4500 Wireless All-in-One...
Our HP Deskjet 6500 wireless copier is stuck on copying 8.5 x 11 about 1/4 of the size smaller...shrunken copies, AH! How can we reset the copier. Thank you April
Thank you for posting your printer problem to FixYa.
  • On the document you want to print.
  • Go to FILE, PRINT (or PRINTER PROPERTIES)
  • The Print Dialog Box will open
  • Click the EFFECTS tab
  • Check the option that says Print document on:
  • Choose the correct paper size from the pull down menu
  • Uncheck the option that says Scale to fit.
Keep me posted.
Jas247
Aug 19, 2011 | HP Deskjet 6500 Series
My HP 4100 printer prints with a black smudge clear down the page. I clean the roller but continues to print bad copies. Should I replace the cartridge?
Problem is either the cartridge or the fuser.
Put paper in the manual feed tray(tray 1)
Print something. When the paper gets 1/2 way into the printer, open the
top cover. Pull out the toner, look down at the paper.
If it has the smudge replace the toner. If no smudge, replace the fuser.
Apr 29, 2011 | HP LaserJet 4100n Printer
I HAVE A MAC OS X 10.4.11. HP OFFICE JET 4500. HOW DO I SCAN? WHAT OPENS ON MY COMPUTER? WHAT SOFTWARE SHOULD I HAVE? I SAW I PHOTO OPEN BUT DID NOT SEE MY DOCUMENT.
OS X driver which allows your Mac to interface with a HP Officejet 4500 wireless all-in-one printer
This is a free Mac OS X driver installer package for the HP Officejet 4500 wireless all-in-one printer.
Enjoy the convenience of wireless connectivity with the Officejet 4500 wireless all-in-one printer. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with tje Officejet inks, you'll get professional-quality color printing at a low cost per page.
http://mac.softpedia.com/get/Drivers/HP-Officejet-4500-Driver.shtml
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 13, 2010 | HP Office Equipment & Supplies
Hp laserjet p3005dn tray1 manual feed problem
Jul 25, 2009 | HP LaserJet P3005n Printer
I have an HP printer scanner 1310 series. Have trouble with printing. It will run about 3 blank pages through before it will print. Then it will run a page part way through so have to open back to get it...
Hi Audrey-
There are many things that will effect how your printer handles paper. The most overlooked being the size of the document or image to be printed. If the image or text bleeds over the edges (left, right, top, bottom) of the document, several sheets can be ejected before the "visible" printing takes place. Often those first few pages look blank, but actually are the outer edges of your picture or text. If you are printing a large picture or large text document, this may be your situation. Try printing a document with just a few words on it (like a small email) as a test.
The second most common culprit is dusty, dirty feed rollers in the printer. Consult your HP 1310 series manual for instructions on cleaning the feed rollers, or consult this general cleaning article on HP.com. HP PSC 1310 All-in-One Printer series cleaning
The type of paper can also effect how many sheets are pulled into the rollers. Is the paper new?, Thick?, Very thin?, or is it the same ol' printer paper you've always used? Either way, remove the stack of paper from the feed tray, "fluff" it by fanning it (like flipping through a book very quickly, or the way Superman counts a stack of money!) and replace. Print a test page.
Let me know if this helps!
Dec 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Envy 4500 e-All-In-One Printer, Copier, Scanner Logo
41 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
