Question about Aqua Swiss Aquaswiss Trax Wrist Sharp $1400 Watch for Men
Setting the time on my aquaswiss bolt L - Aqua Swiss Aquaswiss Trax Wrist Sharp $1400 Watch for Men
How can I tell my watch is a genuine aquaswiss
take it to a watch shop and see if they can tell you.
Dec 23, 2016 | Watches
How do I change time on my aquaswiss swiss sport 24 watch
I looked this up and find many images many have only a winding stem and many had it and 2 buttons . there fore it is tough to guess which you have to even suggest how .post you exact photo and then perhaps we can assist you
Nov 26, 2015 | Swiss Watches
Just got myself the new SWISSport M but it not moving
Your watch is a battery powered watch. If it is not running, the first thing to check would be the battery. To turn it on just push the crown in.
Oct 07, 2012 | Aqua Swiss Aquaswiss Trax Wrist Sharp...
My dog ate the band on my aquaswiss swissport purple watch. where can io order a new one?????
You can call Tag Heuer and order a new band or you can try online sources such as ebay who sometimes sell them at a lower price.
Oct 19, 2010 | Tag Heuer Kirium (CL1212.BA0705)...
How do I set the DAY (not the date) on an Aquaswiss watch? The day is displayed in a separate dial at the 6 O'Clock position on the watch face. The manual does not indicate how to set the DAY. The movement...
Their web site is pretty useless as far as instructions go (as you may have already found) but looking at their range, it looks like your is a "Trax" model.
As a guess, I suggest that you pull out the crown wheel (it may need rotating anticlockwise about a 1/4 of a turn) and pull is out.
I would expect their to be two "out" positions, the second one usually operates the hands and the date, so this leaves only the first position to be available to adjust the date.
Experiment a little to find the function you need!
Sep 18, 2010 | Watches
Looking for an instructional booklet for my aquaswiss sport watch
Thank you for contacting FixYa.<br /> Very difficult to find certain odd brands such as Aquaswiss. You wil have to contact them direct at :<br /> <a href="http://www.aquaswisswatch.com/Scripts/contactUs.asp">http://www.aquaswisswatch.com/Scripts/contactUs.asp</a><br /> <br /> Best regards,
Aug 25, 2010 | Bulova Watch
How do I get a steal band for my Aquaswiss Trex watch?
look for a tag store near by. if u cant find one most jewelry stores with a shop (not in a mall) can either do it there or send it out. sometime the band can be fixed
Oct 07, 2009 | Tag Heuer Kirium (CL1212.BA0705)...
Aquaswiss Trax watch band adjustment
VSNDESIGNS SAYS:
You should first try to adjust the band at the Clasp first. The clasp has three holes that you could easily move your band up or down into. If you need to remove one or more of the links, try the following.
http://www.fixya.com/support/t315141-adjust_band_aquaswiss_trax_watch
http://www.rgmarchitect.com
Feb 09, 2008 | Watches
How to adjust the band on a aquaswiss trax watch
Warning: This is if you don't have any professional watch tools. And I definitely recommend you taking it to a jeweler first.
That being said...
I was able to adjust my band by using a small nail and a pair of needle nose pliers...and Krazy Glue or Super Glue (last warning...you really should take it to pro)...
1. Push the any one of the pins that holds the wristband together until you see it protrude from the other side. While applying pressure to the pin, quickly grab it from the protruding side with the needle nose pliers and pull off the metal cap from the pin.
2. Note you will notice that the pins are actually 2 pieces! They are not screwed together and it makes for a pretty poor design since, one the pins are taken out and then replaced after taking out the appropriate links... they tend to get loose and you will lose that tiny metal cap that holds the pin in place.
3. A professional will have a clamp that is small enough to press these two pieces together. But even that is precarious. I strongly recommend that you carefully apply a drop of crazy glue on each end of the pin, after you are finished.
Final note: I was luck to have spare pins from the links I removed to replace the pin that worked out of its cap. That little sucker is lost to the watch gods. Have fun! Also... you can make final adjustments at the 3 pin location at the wristband release.
Hope this was helpful!
vsndesigns
Dec 25, 2007 | Tag Heuer Kirium (CL1212.BA0705)...
Aqua Swiss Aquaswiss Trax Wrist Sharp $1400 Watch for Men Logo
82 people viewed this question
Top Aqua Watches Experts
Ansel Alberto
Ansel Alberto
Are you an Aqua Watch Expert? Answer questions, earn points and help others
