It has a cool selection but that doesn't work. We turned the heat to 72 and now it is up to 84 and won't shut off. We've tried taking the batteries out, turning it off, flipping the fuse...nothing turns it off. How can we get it to shut off?
SOURCE: Maytag MDBH970AWS Heating element won't turn off
The heater relay is located on the control board, a faulty relay or a faulty control board would cause the problem you have described. The fix is to replace the control board. Parts for your unit should be available from most appliance parts retailers, if there is not one local to you, the part is available at www.apliancepartspro.com. along with an exploded view of your unit
Hope this helps.
please take the time to rate this solution
SOURCE: My heater fan won't turn off when car is off 88 Buick Lasabre?
I have the same problem on a 1988 lesaber Climate control and was told to change the climate control as the was the problem. A have the climate control but have a problem to take of the cover that covers the control and the radio. If any one can tell me how to remove it I will put in the new control and see if that will stope the fann.Thanks
SOURCE: my thermostat quit working
I work alot with the Honeywell thermostats and in the past couple of years I have seen the Vision Pro thermostats have some fail issues. There is a 5 year warranty on these thermostats so you should'nt have to pay for a new one if it's under 5 years old.
SOURCE: Stuck on Flip Video logo when I turn it on & can't turn off!
Yes this can sometimes happen if the camerafreezes. Use the reset button to recover it from this state. If it freezes more frequently and you experience decreasingbattery runtime, you may need a battery replacement. There is a servicethat can fix common issues like the battery screen, on Flip VideoCameras Flip Video Repair
SOURCE: My Bose QC15 won't turn on, I've already tried replacing the battery. What could be the problem?
Mine did this as well, totally frustrated I kept on rapidly switching them on and off, and eventually it just switched on!
