Question about Home
Posi??o do comando d? sw4 - Home
How to wire two lights from one soure that have two differant switch with one being a 2 way?
In the schematic supplied, there are several options.
SW1 which is a regular SPST single pole single throw switch will open (off) or close (on) the circuit to lamp LA1.
SW2 is a two-way switch which turns LA2 off/on via SW2a.
SW2b is not connected.
SW3 and SW4 are two 2-way switches to switch LA3 on or off from either SW3 or SW4.
When both are in position a or position b then LA3 is on.
Otherwise LA3 is off.
This is often called 'staircase switching' as it can be used on a staircase.
Dec 02, 2017 | Dryers
I have a Hannspree LCD TV Model HSG1113, the big yellow transformer on the power board has burnt (2cm area) the PCB underneath it. There's a type of fuse (f901) T4AL 250 V that's blown. How can...
eu tenho um lcd ke o comando a distancia nao funciona e o led pisca a laranja mas o mesmo comando noutro lcd funciona o ke tenho ke faser
Jun 11, 2011 | Televison & Video
What rear end can I replace for posi trac
youd have to drop the differential covers in the junkyard til you found one with posi. posi was optional on the trucks.
Oct 06, 2010 | 1989 Chevrolet C1500
I have a 71 C10 with a posi rear end. When I turn
Make a series of tight turns in both directions if posi plates are stuck often that will free them. I have no idea what a chunk is so I'll refrain from commenting on that one.
Sep 27, 2009 | Chevrolet Chevy Cars & Trucks
My shower has been leaking for months. someone
turn the water off to the shower,sometimes you must shut down the whole house at the main ,near the water meter,then take the handle off slide the clip in front up and out then pull posi-temp straight out.replace posi-temp in reverse order.be mindful of the H/C indicator on posi-temp this will ensure you have hot and cold on right sides,if reversed just flip posi-temp.
Jul 08, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Janesong universal remote codes
Hi have a janesong remonte control and no code for a sharp tv can anyone help thanks
Feb 24, 2009 | Directed 434MHZ Remote Control
Comando para ver clientes conectados
After logging into the EOC-3220 with Telnet, enter:
cat /proc/wlan0/sta_info
Mar 20, 2008 | EnGenius EOC-3220 (EOC3220)
Home Logo
42 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
