Question about LG Washing Machines
How do you fix a LG dryer pedestal drawer that won't stay closed and there is nothing behind the drawer to cause the problem?
  • LG Master
  • 5,323 Answers
Sounds like a balance issue, you may need to balance the legs on the appliance, try using a leveler on the top of machine
Posted on Jan 14, 2017
the dr
  • 447 Answers
SOURCE: remove pedestal drawer from washer
First remove the top of the washer via 3 tork, 7mm hex head screws (they are hidden located on rear of washer) then you can see to line up the tub with the shipping bolts. Just put 2 in --one lower and upper opposing each other and that will be sufficient. I believe there is two screws holding the drawer in located at the track towards the front of the drawer. Now you can lean it over with no worries to remove pedestal
Posted on Jan 12, 2008
  • 1028 Answers
SOURCE: kenmore pedestal for the front loading elite washer and dryer
some pedistals have a screw on drawer just behind front on end of rail newer ones have a small black lever on each side ..pull drawer completely out lever is about midway at end of inner rail pull lever 1 up other down drawer will pull off rail reinstall by sliding rails back together and pusing all the way in
Posted on Jun 11, 2008
  • 848 Answers
SOURCE: remove washer pedestal drawer
  • Open the drawer fully. Look at the rear of the support slide is there a small, black plastic lever on one side push the lever down, the other side pull the lever up.
  • Remove the small screw on either side of the support slide at the front of the drawer. Lift the drawer and push support slide away from the drawer
Posted on Oct 30, 2008
SOURCE: how to remove drawer on pedestal
You need to remove the 2 screws holding the black rails on both sides of the drawer. Took us a while to figure this one out also.
Posted on Jan 31, 2010
SOURCE: LAB2700ML Optional Pedestal Drawer for Duet® Washers & Dryers PEWTER: How do you remove the drawer?...
how does the drawer come out of the base
Posted on Aug 01, 2010
My electrolux washer/dryer pedestal will not stay closed. I am looking for how to order the part
Good Afternoon Dani, thank you for your post!
From my understanding your Electrolux pedestal is not remaining closed. You may need to replace the latch or rails inside of the pedestal. I can provide you with further part information once I have the model number of the pedestal. You can locate that information on the door frame of the pedestal. I look forward to helping you further. -Matt
Feb 15, 2016 | Electrolux Washing Machines
Remove washer pedestal drawer Cannot remove drawer to check behind or underneath, please help.
Oct 30, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
How do I remove a pedestal drawer on and electrolux dryer
Hello friend, thanks for your inquiry!
I have researched that information for you and was unable to locate steps on how to remove the drawer from your pedestal. I would suggest seeking assistance from a professional for proper removal of the drawer. Hopefully this helps. -Matt
Sep 28, 2014 | Electrolux Washer/Dryer Laundry Pedestal...
Electrolux pedestal drawer won't close
Good Afternoon Apetgroomer,
I see that you're having trouble with your Electrolux pedestal drawer, model# EPWD15TS, door not closing. There are 2 pieces inside the drawer that help to keep the drawer shut that could be broken. One is the drawer strike, which is actually attached to the drawer itself. The other is the drawer actuator, which is attached to the casing which holds the drawer. Check both of these parts, and if it is one of them, i suggest contacting the manufacturer to se if they have any replacement parts.
-Best Regards-
WP
Apr 02, 2014 | Electrolux 15 Turquoise Sky Pedestal...
Drawer will not stay closed
Hello David, I am JK. I understand that you are having trouble with the drawer staying closed on your pedestal. I would recommend checking to make certain that nothing is caught under the pedestal keeping the drawer from closing properly. If this is not the concern, the strike and/or latch might need to be replaced.
Hope this helps!
Mar 05, 2014 | Electrolux EPWD15IW
Drawer catch broken
Hope this helps!
How to remove drawer on pedestal
Jan 01, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
Samsung Pedestal Drawer
If you pull out the drawer (completely) you should find 1 or 2 screws on each side that bolts the slider to the drawer. Remove these, then lift out the drawer. This then gives you full access inside. ...JimS
Jul 31, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Kenmore pedestal for the front loading elite washer and dryer
Jun 10, 2008 | Kenmore 15.5 in. Pedestal
Front Load LG Washer and Dryer Pedestals
If the pedestals are properly installed they pretty much become part of the washer and dryer and if those are installed correctly you will have no more vibration then if the units are sitting on the floor. If possible get the washer as close to an outside wall as possible since the floor is stronger there.
Jan 28, 2008 | Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
