How do you rewind a cassette on an Exuby record player?
  • 3 Answers
SOURCE: A pinging sound whenever i try to record something or rewind the cassette
It sounds like there's a problem with the tape loading mechanism. The first thing you should try is seeing if the camcorder will allow you to run a head cleaner through it (probably not the problem, but something everyone should do regularly, but most people don't). If that's not the issue, then it's probably something that you can't fix yourself. You should have information in the box that tells you where to send it to for repair. Good Luck.
Posted on May 25, 2007
Buffalo12980
  • 625 Answers
SOURCE: RCA cassette recorder/player keeps shutting off. argggg
fast forward, reverse the cassette and fast forward again. if the tape is too tight the current sensor will always trip out the motor.
Posted on Dec 31, 2007
  • 275 Answers
SOURCE: Cassette player won't play
Most likely all that you need is to replace the belts set.
Posted on Jun 18, 2008
SOURCE: Cassette Recorder play problem
Left(Playback) deck of cassette player turns off within about 2 sec's after inserting a cassette to play. Rewind and Fast Forward stop also after about 1 to 2 seconds. When pushing button to play it turns back off right away. I suspect the end of tape/tension sensor is the culprit but do not know where it is. Have not taken any steps except finding this site first off!
Posted on Jul 24, 2008
battlesmith
  • 382 Answers
Belts are prone to harden over time,the belt will be broken so replace it.. Also as you say the unit does turn off which is the problem of Take-up reel sensor ..Try to Take to any Service person and replace it,your player will be back in condition..Thank you..
Regards!!!...
It is problem in Take-up Reel section and its not sending signal to processor. How old is this unit?
Jul 24, 2008 | Onkyo TARW255 Single Dual Cassette Deck
What is the reason the tape won't play on sa-ak95
It may be the tape(s) themselves. Pre-recorded cassette tapes are usually no problem for most players, but many user-recorded tapes were of the C90 or C120 variety. These cassettes use much thinner tape in order to get the recording time. This can cause the tape, after many starts and stops and partial fast-forwards and rewinds to get tight on the reels. This will cause the tape sensor to think that the tape is at the end of the reel when it is not. Sometimes rewinding from end-to-end will help, but not always,
Nov 07, 2014 | Microwave Ovens
Video cassette player/recorder LGRC 689D wont rewind properly
The problem is in the idler assembly inside the machine, some use rubber that dry out and crack, or there is a spring loaded double clutch wheels that get weak over time. In order to fix this the idler assembly must be replaced.
May 04, 2012 | Televison & Video
I have a JVC (stereo, radio, cassette, recorder) and it's buzzing
If it is only when the tape is running, it could be motor noise.
Worn bearing in the motor or maybe a suppressor has failed, if it has one.
Oct 09, 2017 | JVC RC-EX25 Radio/Cassette/CD Boombox
Sony tcd-d8 won't rewind
sounds like a belt slipping try renewing them they are fairly cheap to replace.sony tend to be very reliable but this is quite an old item now and belts degrade with time and use.farr64
Apr 30, 2009 | Sony Walkman TCD-D8 Personal Cassette...
Sony Walkman cassette player/recorder will not rewind the tape
Fat chance to repair yourself! we repair that WmD6c but very hard to do!
Feb 23, 2009 | Sony Walkman WM-D6C Personal Cassette...
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
 Grubhead
Grubhead
