Wiring dual 128 to runs in 110 volts
I HAVE a dual 1228 RUNS VERY FAST HOW I CAN CHANG THE MOTOR WIRES TO RUN IN N11Q0 VOLTS
  • 10865 Answers
SOURCE: Wring for trolling motor
just hook the two batteries up in series. To do this buy one short cable and use it to hook the positive of one of the batteries to the negative pole of the other. Then use the two remaining poles, one positive and one negative to hook up to the motor. good luck
Posted on Jan 18, 2009
CarlGehrke
  • 169 Answers
SOURCE: have a 110 volt mig wire feed. motor slows to a
To get parts for your welder you'll need to have the serial number off the tag on the case. This problem could have other causes, have you:
Checked the tension on the wire spool? You ought to be able to pull the wire by hand easily.
Checked the tension setting on the pinch rollers? Too much tension can drag down the motor speed.
You could also have a bad control card depending on which model wire feeder this is.
Regards,
Carl
Posted on Mar 01, 2009
  • 358 Answers
SOURCE: how to wire motor to dual run capacitor
The easiest way to do it is to get a capacitor just for the fan motor (in the motor tag you can read what size cap. you need , maybe 5uf or 7.5 uf) and put the two brown wires on each side of the capacitor and the lines (probably white and black) to the contactor.
Posted on Sep 27, 2009
  • 6 Answers
SOURCE: Dual 1228 turntable platter not spinning, the motor will not turn
If the motor is not spinnig then it is probably seized. These motors are very robust and rarely need replacement parts. Remove both the top and bottom bearings, clean shaft and bearings with solvent and then fill bearings with light machine oil. The bearings have a sponge inside which will soak up lots of oil for years of trouble free use. Once reassembled, tap the bottom bearing while the motor is spinnig and the bearings will centre themselves. If the idler and it's mechanism is working ok as well then you should feel lots of torque from the from the platter when it is spinning.
Posted on Oct 27, 2009
Tnsiouxfalls
  • 617 Answers
SOURCE: I need a multi 110/230 volt wiring diagram for a
http://www.baldor.com/support/literature_load.asp?ManNumber=MN1240
You didn't give a model,here's a manual on their motors and the wiring diagrams,they start on page 2-9.It should get you there,or you can check out their other manuals on the same page .Take care!
Posted on Jan 13, 2010
This is not a question about a dryer! I have a Sears 10 inch Radial Arm Saw. How do I switch the motor from 220 volts to 110??
If the motor is a dual voltage type the instructions might be printed inside the motor cover or alternatively in the saw handbook.
It is important to find the correct instructions and to follow them exactly.
Dec 23, 2016 | Dryers
Wirinmg diagram for SEARS12" tablesawMod#11324181 Serial# 7297Poo56
Please contact Sears on this, we do not have these diagrams here.
Dec 02, 2016 | Pool & Spa
How do I wire GE# 15351 24hr mechanical timer switch for 110 volt outdoor landscape lights
15351 is 240 Volt timer... requires 240 Volt to run clock motor.
You need a neutral wire to connect 120 Volt lights.
15351 has same wiring as Tork 1104
http://waterheatertimer.org/images/Tork-1104-wired-to-control-120.jpg
http://waterheatertimer.org/Basic-house-wiring.html#basic-wire
Gene
Sep 26, 2014 | Electrical Supplies
Proper wire hook up
black goes to L1 white goes to L2 make sure to look on side of motor to change from 220 volt to 110 volt either a knob or changing wires brown and white to different locations hope you didnt fry motor
Jul 26, 2013 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
Single phase motor 220 convert to110v; do you have switch wire inside the motor
There should be a label showing the change, one wire gets switched over to a different screw, all motors are different, but all basically the same, some will not switch. It would be just as easy to run a new line to your motor and it will be right, single circuit, 220 volt,?amp, no worries., Your motor as is will not run in 110 volt mode at all. Hope this helps.
Feb 26, 2012 | Delta Table Saw Tool Base 50279 Band Saw...
I want to re wire an electric motor for low volt
Look on the name plate. If it says under 'volts' 120/240 that means it's dual voltage and you can use either voltage to run.
Sep 25, 2009 | Electric 1hp 1800RPM 56C Frame 12 Volts Dc...
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Voltage problem
Most direct-drive electric compressors can run on a standard 110-volt circuit. When you get into the electric wheelbarrow compressors, you may have a choice for a dual-voltage option, which allows you to switch between 110-volt and 220-volt, depending on power supply that is available for the job. However, for jobs that require substantially more air, usually a 220-volt motor will be your only choice if a gas-powered compressor is not allowed as an option. When looking for a stationary shop compressor, you need to know what power supply you have at your disposal (208v, 230v, or 460v), and whether it is a single-phase or three-phase power. These units are usually hard-wired into the power supply and require a magnetic starter for thermal overload protection
Aug 27, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Wiring a stove
If there is no 220 outlet in the location where you're planning to put the stove then you need to run wiring to the new location. There are two seperate phases of 110 volts coming to your home. The voltage between each of these phases and the neutral wire is 110 volts. When your house was wired only 1 of the 110 volt signals was run to your 110 volt outlets. In order to create a 220 volt outlet you need both of the 110 volt signals run to the outlet.
If you have a straight shot between your breaker box and the location where you need the 220 volt outlet then this is not too big a deal. If you have finished ceilings and walls inbetween then this will be much more difficult.
If you're not comfortable with electrical wiring this would be a good time to call a licensed electrician.
Nov 18, 2007 | Ovens
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
