Question about Watches
How do I take alarm time off for days I don't need it
C9 champion digital alarm
Since you don\'t know how to turn it off, the alarm will give you simple instructions. Just stop pressing the buttons. Is there a symbol or an alarm or clock on any of the buttons?
May 10, 2013 | Watches
Removing hourly chime from a sportek watch
I know it's been a year since this question was asked, but I was trying to find the answer today and finally figured it out. I thought I would answer for someone else.
I have a sportek SP1020ZEL. Pressing mode first and then alarm did not work for me. Pressing mode first on my watch only put it into the stopwatch mode, and then pressing the alarm button is for reseting the stopwatch. So I tried it the other way around, and it worked.
First, press and HOLD the alarm button (bottom right button) and then the mode button (bottom left button). My sportek doesn't show a little bell symbol, but I noticed that with one press all the days of the week showed and when I pressed again all the days disappeared. So I waited for the hour and found that when there is no days of the week visible the hourly chime is off. I don't think this works with all sportek watches but it is worth a try. (I did not try holding all the buttons for 5 seconds).
Jun 17, 2011 | Watches
I have misplace my manual and I was wondering how to turn off the hourly chime. ms 1000
Get to the alarm screen by pressing the mode button as many times as you need to. At the alarm screen, a short press on the lap-reset button toggles the chime on and off. Don't press and hold the lap-reset button: that toggles between alarm 1 and alarm 2.
Apr 27, 2011 | Champion International soccer referee...
NEED AQUALITE MANUAL - CAN'T SET TIME
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press any button on the watch.
Apr 09, 2010 | Watches
NEED THE INSTRUCTIONS FOR AN AQUALITE 100 jstreiter@comcast.net
To set time:
To set Alarm time:
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "ST./STOP" button on the watch.
Mar 26, 2010 | Bulova Watch
I have a Champion Sports Referee Watch. I need to
Mar 16, 2010 | Champion Watches
Seiko chronological alarm watch
I looked at the Seiko web site and found only one of the listed watches was described as a "chronometer" and that one did not have a daily alarm.
To review the instructions, go to "seiko.com", then "support" and click on "instruction booklets".
There is a diagram showing where the information is that should be entered to give the instructions you need.
Alternatively, below the diagram is a list of watches which you may be able to find your watch .
Feb 16, 2010 | Watches
How do you set the time?
To set time:
To set Alarm time:
Jan 13, 2010 | Watches
SKAGEN 521LBLB1 ALARM INSTRUCTIONS
everything you will need is right here.
http://www.skagen.com/service/watchInstructions.fx
p.s. there is another little stem on the lower right side that controls the alarm it must be pulled out.
May 08, 2009 | Skagen Alarm Watch Black Square 521LBLB1
Alarm
Alarm Setting:
1st: Press the mode button to go to the alarm screen.
2nd: Press the adjust button for the time to flash
3rd: (For the Hourly Alarm) You can adjust the time here while it is flashing by pressing the start/stop button. Cycle through this until you have the time you want. The setting will have the P in the left side of the screen for PM (night time).
4th: (For the Daily Alarm) Do steps  1-3 once the time is flashing use the Mode button to cycle through to the date field of the watch. Once it is flashing you can use the Start/Stop Button to chose which date Month/Day, after chosing the month just press the Mode button once more to go to the day field.
Jan 05, 2007 | Casio DW9052-1V Wrist Watch
Watches Logo
13 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
