I have an AR-REF3E Fujitsu. Turned it on, with setting to cool mode, with temp set at 18 degrees C with fan on max... it has worked for about 20 minutes, but the room is not really cool at all?
  • 50 Answers
SOURCE: Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
Posted on May 18, 2008
  • 57 Answers
SOURCE: fan runs constantly on cool mode
Simple Question: Did you check to see if the fan switch on the
t-stat is in ON or AUTO? If ON the fan runs nonstop. If in auto the fan cycles with the outdoor unit.
next does the fan shut off if you turn the t-stat to off?
A stuck relay should keep the fan running all the time.
Sometimes if the relay is stuck you can whack the side of the Air Handler and the connection will break.
Sometimes instead of a relay there is a stack switch.
It's a little black stack of 3 disks this is a bi-metal switch.
they do get stuck more often than relays.
The fan relay may be on a electronic board. I don't know for sure without seeing your unit.
Good Luck Phil
Posted on May 20, 2008
SOURCE: room temperature has not changed since hooking up new portable a/c
I bought mine last summer. Used it once or twice. Hooked up it today and it is a piece of ****. Been at 34celsius for the last 4 hours and still not even close to being cool .. and its in my bedroom
DON'T BUY DANBY portable a/c -----------
Posted on Jun 07, 2008
SOURCE: Getting the room down to temp....
Push the down arrow to a lower temperature.
Posted on Aug 18, 2008
  • 101 Answers
SOURCE: No heat in my 2000 GMC Sonoma w/AC. Engine warms
that year / series of GM sonoma and s-10 where famous for having clogged heater cores - is temp of hoses going in and out the same ? if not try to flush out ther core, if they are, ck to see if the hot water valve is woking, and finally operation of the doors inside the heater box itself
Posted on Oct 18, 2009
Testimonial: "Success! Reverse flushing heater core fixed problem. Less than a tablespoon of dirt came out yet it gave no heat. Now works great. Thanks much. Jim."
I need help on how to activate heating mode in my 7wa4501q whirlpool 6th sense minisplit pleasee
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Jan 13, 2011 | Heating & Cooling
Our Fujitsu inverter although on 18 degrees and "Cooling" on high is not cooling at all. Just feels like a fan on high
First advise not to keep in 18 degree temp.(Please ask me why in separate question)
You will get better cooling in 23 degree itself. There are many reasons for not getting cold.
1. Dirty filter and coil. Clean it. 2. Check compressor is working. 3.If working, check for gas pressure. 4. If gas pressure is good, check out door fan motor working well. 5. And also clean your condenser coil.
Helpful?
Jan 03, 2011 | Fujitsu 18C1 Air Conditioner
What do the symbols on the display mean and which one does the cooling operate better on . model number kyd-32a thanks
Now symbols:
4. Sun- Heat
Dec 31, 2010 | Heating & Cooling
Don't have a manual i just wan't to know what settings are what ..re symbols on screen on control
Now symbols:
4. Sun- Heat
5. A or AU- Auto mode.helpful?
Rent a house with a daikin brc1c51/61 with no instructions on how to work control panel for cooling/heating
Now symbols:
4. Sun- Heat
5. A or AU- Auto mode.For further details, plz:
www.devicemanuals.com/guide/.../Daikin-manuals.html
Dec 30, 2010 | Heating & Cooling
No cold air
Check temp setting minimum 3 degree less than room temp and mode in " Cool" . If no cool check compressor is working or not.
Dec 30, 2010 | Fujitsu Heating & Cooling
I have a brand new york inverter air conditioner that does not want to cool!
Now symbols:
4. Sun- Heat
5. A or AU- Auto mode. First, check your compressor is working?
Dec 29, 2010 | Heating & Cooling
We bought a house with Fujitsu Air-conditioners we have no instruction manual on how to use the remote. Im trying to set it to go off after an hour or so. Model No.INDOOR UNIT is, AST12RSJCW Serial No is...
Switch on by pressing ON/OFF. Press mode button to cool position. for cool and keep required temp by clicking
Same procedure for Heat. For heat keep +29 and for cool 25 to 22 degree. Press fan for High, Med,Low. If you keep mode in Auto cool and the fan speed will be low and you can't change fan speed.
Please visit Fujitsu website for further details. Hope my msg is helpful?
Dec 09, 2010 | Fujitsu Heating & Cooling
Temp will not set above 32 degrees but will go
You may have a thermsotat problem if you get it to cool that low it will cause the condensor to freeze and will stop it from working.
Jun 05, 2010 | DeLonghi CF210 Portable Air Conditioner
Problem with mitsubishi air roof units
to tricked the thermostat only a way i know,to put on it an ice cube for a while.propably wrong choice to installed roof unit you must installed to the floor better for the ac and to you
Dec 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
