Question about Pool & Spa
Dual 1228 dual turntable wiring motor to runs in 110 volts
5 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: have a 110 volt mig wire feed. motor slows to a
To get parts for your welder you'll need to have the serial number off the tag on the case. This problem could have other causes, have you:
Checked the tension on the wire spool? You ought to be able to pull the wire by hand easily.
Checked the tension setting on the pinch rollers? Too much tension can drag down the motor speed.
You could also have a bad control card depending on which model wire feeder this is.
Regards,
Carl
Posted on Mar 01, 2009
protek480
  • 1723 Answers
SOURCE: I want to re wire an electric motor for low volt
Look on the name plate. If it says under 'volts' 120/240 that means it's dual voltage and you can use either voltage to run.
Posted on Sep 26, 2009
  • 6 Answers
SOURCE: Dual 1228 turntable platter not spinning, the motor will not turn
If the motor is not spinnig then it is probably seized. These motors are very robust and rarely need replacement parts. Remove both the top and bottom bearings, clean shaft and bearings with solvent and then fill bearings with light machine oil. The bearings have a sponge inside which will soak up lots of oil for years of trouble free use. Once reassembled, tap the bottom bearing while the motor is spinnig and the bearings will centre themselves. If the idler and it's mechanism is working ok as well then you should feel lots of torque from the from the platter when it is spinning.
Posted on Oct 27, 2009
wilsodfarm
  • 986 Answers
SOURCE: wiring ??? I'm installing dual 12 volt battery's
pos to pos and neg to neg for 12 volt but if your system is 24 volt thats a different story it will be pos to neg.and pos to neg
Posted on Nov 02, 2009
This is not a question about a dryer! I have a Sears 10 inch Radial Arm Saw. How do I switch the motor from 220 volts to 110??
If the motor is a dual voltage type the instructions might be printed inside the motor cover or alternatively in the saw handbook.
It is important to find the correct instructions and to follow them exactly.
Dec 23, 2016 | Dryers
Dual 1218 turntable
Does it say anywhere you can find that this turntable can run off 220V mains? Most are run directly from the AC and the motor is an induction motor meaning it needs a specific voltage and cycles per second to run properly. You may find that the manufacturer provided straps on the motor that can be unsoldered and changed to adapt to various voltage and ithat the speed can be altered via a speed control knob on the top to adapt to 50 or 60 cycles.
Apr 28, 2014 | Technics Audio Players & Recorders
How i can switch husky compressor 110 for 220 ? Txs.
If the motor is a dual voltage motor just connect the wires according to the label on the motor. Otherwise you'll need to get a 220 volt motor that turns the same direction as the one on it now.
Sep 27, 2013 | Air Tools & Compressors
Single phase motor 220 convert to110v; do you have switch wire inside the motor
There should be a label showing the change, one wire gets switched over to a different screw, all motors are different, but all basically the same, some will not switch. It would be just as easy to run a new line to your motor and it will be right, single circuit, 220 volt,?amp, no worries., Your motor as is will not run in 110 volt mode at all. Hope this helps.
Feb 26, 2012 | Delta Table Saw Tool Base 50279 Band Saw...
I have a Rowe R-89 jukebox. Even though the motor is turning on the turntable, the turntable is not moving. Should there be a washer on the turntable base to elevat it so it will turn?
Hello Robert,
You say you have a R-89 jukebox and the turntable motor is running, I assume that the pulley on the top of the motor is clearly seen turning. Is the turntable belt loose or missing?
From your message I am not sure that your jukebox is a R-89, could it be a 1978/1979 R-82 or R-83 that uses an idler wheel.
On this model the turntable motor is 110 volts AC.
If the above is true check that the idler wheel and the linkage spring is pulling the idler wheel against the turntable and the motor shaft.
Regards
Alan Hood
ami-man
UK
alan-hood@datex.co.uk
Aug 19, 2010 | Wurlitzer Jukebox CD Player
Sep 25, 2009 | Electric 1hp 1800RPM 56C Frame 12 Volts Dc...
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Dec 19, 2008 | Audio Players & Recorders
Voltage problem
Most direct-drive electric compressors can run on a standard 110-volt circuit. When you get into the electric wheelbarrow compressors, you may have a choice for a dual-voltage option, which allows you to switch between 110-volt and 220-volt, depending on power supply that is available for the job. However, for jobs that require substantially more air, usually a 220-volt motor will be your only choice if a gas-powered compressor is not allowed as an option. When looking for a stationary shop compressor, you need to know what power supply you have at your disposal (208v, 230v, or 460v), and whether it is a single-phase or three-phase power. These units are usually hard-wired into the power supply and require a magnetic starter for thermal overload protection
Aug 27, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Pool & Spa Logo
54 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
