Wiring for motor 1228 Dual turntable I want to connect my dual 1228 in 110 Volts something is wrong with wires runs very rapidly
2 Suggested Answers
  • 6 Answers
SOURCE: Dual 1228 turntable platter not spinning, the motor will not turn
If the motor is not spinnig then it is probably seized. These motors are very robust and rarely need replacement parts. Remove both the top and bottom bearings, clean shaft and bearings with solvent and then fill bearings with light machine oil. The bearings have a sponge inside which will soak up lots of oil for years of trouble free use. Once reassembled, tap the bottom bearing while the motor is spinnig and the bearings will centre themselves. If the idler and it's mechanism is working ok as well then you should feel lots of torque from the from the platter when it is spinning.
Posted on Oct 27, 2009
This is not a question about a dryer! I have a Sears 10 inch Radial Arm Saw. How do I switch the motor from 220 volts to 110??
If the motor is a dual voltage type the instructions might be printed inside the motor cover or alternatively in the saw handbook.
It is important to find the correct instructions and to follow them exactly.
Dec 23, 2016 | Dryers
How does one configure for 115 and 230 volts?
It varies. You will need to contact the mfr.
Apr 06, 2015 | Pool & Spa
Dual 1218 turntable
Does it say anywhere you can find that this turntable can run off 220V mains? Most are run directly from the AC and the motor is an induction motor meaning it needs a specific voltage and cycles per second to run properly. You may find that the manufacturer provided straps on the motor that can be unsoldered and changed to adapt to various voltage and ithat the speed can be altered via a speed control knob on the top to adapt to 50 or 60 cycles.
Apr 28, 2014 | Technics Audio Players & Recorders
Installing sterio
Buy an installation kit to ensure proper connections...
Also, don't buy a DUAL deck...junk
Jan 03, 2014 | 1986 Mercury Grand Marquis
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
Aug 05, 2010 | Hobart H600 Stand Mixer
I want to re wire an electric motor for low volt
Look on the name plate. If it says under 'volts' 120/240 that means it's dual voltage and you can use either voltage to run.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 25, 2009 | Electric 1hp 1800RPM 56C Frame 12 Volts Dc...
My air conditioner fan motor runs in reverse thus, none or very little air is coming out
The fan motor can be wired correctly for up flow and still run backwards for downward flow or reverse when you put the wrong value capacitor or connect a hard start capacitor to an already bad start dual cap. Case in point: I come across a condenser where the fan motor is running (in the right direction, up) but the compressor is not. I put a hard start cap on the dual cap. The compressor comes on but now the fan motor runs reverse. No other wiring was changed. The hard start cap connected to the defective compressor start cap shifted the current, voltage phase 180 degrees to make the fan motor run backwards. I removed the hard start cap, removed the defective dual cap and replaced the dual cap with a known good one and everything worked correctly.
Jul 09, 2009 | Heating & Cooling
Dec 19, 2008 | Audio Players & Recorders
Neptune dryer
there is no transformer in the dryer, i am guessing you have a 110 v motor and when you hooked the plug wrong, you could have supplied the motor with 220 v that's why you can smell something burnt.
the heater is 220 volts. regular dryer has dual voltage supply. 110 v and 220 volts.
tnx 4 using fixya,
drcool
Sep 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
