Question about Juicy Couture Watches
My Juicy Couture watch keeps losing get time about 30 minutes just bought it 2 weeks ago
  • Juicy Couture Master
  • 14,921 Answers
Take it to a local jeweller and ask them to calibrate it which is done electronically. Fakes are renown for losing or gaining massive amounts of time.
Posted on Dec 29, 2016
zeusfaber
  • 247 Answers
SOURCE: luminox 3001 watch not keeping time
Because of the way they work, it's quite hard for quartz movements to run consistently slow - so if you find one getting behind, it's usually a sign that it's stopping intermittently. It would do no harm to check that the crown is properly pushed in after you've reset it, but my guess is that the watch will benefit from a new battery. A.
Posted on Apr 08, 2007
escapement
  • 2334 Answers
SOURCE: Garmin 50 forerunner failure
It sounds to me as you are having the problem with faulty contacts. They should be cleaned and checked for stiffness- if too weak must be replaced.
The next possible cause can be integrated circuit (IC) failure. In this case only skilled watchmaker can help you and that gonna be costly.
Posted on Dec 17, 2008
  • 5 Answers
SOURCE: new watch is losing 5 to 15 minutes a day
This could be that the battery is slow. Newer swiss watches have a indicator in the movement of the watch that makes the sweep second hand skip every few seconds to indicate that the battery is slow. On regular japan made watches the watch just simply starts slowing down. Your watch could be new but the battery in it could have a long shelf life.
Posted on Aug 11, 2009
  • 183 Answers
SOURCE: Suunto watch keeps resetting itself. Changed
You wouldnt think a whole lot could go wrong with a Suunto battery change. If they had trouble getting the coin access back off and unscrewed the case then the button contacts might be out of line causing your problem. You might also check to be sure that they put the right battery in and that there are no pry marks as sometimes there are problems getting the battery out. If any excessive pressure was placed on the circuit board and it cracked it will need to be replaced.
Posted on Sep 22, 2009
  • 2501 Answers
SOURCE: My wrist watch is continuously losing time. It is
go to the Timex web site "timex.com".
Scroll down to the bottom of the page and select "manuals/downloads."
Select "Product manuals downloads"
Enter you model number in the search box.
Choose your download from the list.
Posted on Jan 05, 2010
How to remove link from juicy couture watch
That can be described in a really good essay like http://www.writemyessay24h.org/, which may actually give you a lot of interesting information.
Mar 26, 2013 | Juicy Couture Rich Girl Round Dial...
Can't set juicy watch
pull crown out then you can turn to correct time then push crown back in
Aug 23, 2012 | Juicy Couture WomenS 1900727 Hrh Hot Pink...
Juicy Couture 'Dalton' Watch i cant figure out how to open it to wear
Hope you've already got it figured out, but if not... you have to give it a good pull on the back of the link bracelet. Hold it with your fingers on the edges (sides) of the links and give a strong pull just to the side of the round button on the underside of the watch bracelet. One side comes off before the other, so if it doesn't click open, try the other side of the round button. It'll open half way, then do the same thing on the other side. You won't hurt it :) Beautiful watch. Mary
Dec 25, 2009 | Casio Watches
Analog hands lose time when worn.
This is usually a indication that the minute hand is slightly loose on its pinion. This requires that the hand be tightened, so that it does not slip. Best left to a watchmaker.
Nov 23, 2009 | Casio AMW320R 1EV Casual Sports Watch
Bulova has mechanical day/date display near 3 o'clock position, electronic watch (quartz I presume) less than 3 yrs old. Started losing time. I assumed the original battery needed to be replaced. Battery...
I believe you are just outside your warranty. Its time to see a watch maker/technician about repairing the watch. Often times slowing is as easy to fix as lubricating the movement and forcing the gear train through the use of a cyclonic device. This fix takes minutes and is very cost effective. If the slowing is due t circuit board issues or a more sever gear train problem then the movement will need to be overhauled. I suggest comparing this cost to the cost of a replacement movement.
Sep 22, 2009 | Bulova Watch
All my watches losing time
good day,
hope this link below will solve your problem.
watches
Feb 25, 2009 | Skagen 355LGSC Wrist Watch
Luminox 3001 watch not keeping time
Apr 08, 2007 | Luminox Navy Seal Dive 3001 Wrist Watch
Watches Logo
22 people viewed this question
Top Juicy Couture Watches Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Juicy Couture Watch Expert? Answer questions, earn points and help others
