Question about Nokia 2600
Not charging connect the chager to mobile and display messege is not charging
    President:
  • Nokia Master
  • 2,923 Answers
Try using another charger. If you get the same problem even though you're using a known working charger, then it could be the battery.
Posted on Jul 21, 2009
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Contact service
Contact service means your mobile is locked with some network , so when you on the mobile it displays as contact service ,so for this problem you have to unlock your mobile, if you unlock means after that you can use any network at any where in the world.......
Get the unlock code for your Nokia 6300 model mobile through this site Theunlockarena.com , it has the best instructions and easy methods for getting the code for your mobile from the network lock......
Jan 03, 2012 | Nokia 6300 Cellular Phone
Spice m-4580 invalid charger problem.
SIR. 4580 MOBIL ME CHARGING INVELID LIKHA AA RAHA HAIN
Sep 05, 2011 | Health & Beauty
I have aRascal model 245 scooter,I was driving it when all of a sudden it shut down, and batt indicxater went into the red zone.I tried charging the battery with the built in charger but did not work. But...
Replace the batteries because they are too low to give you enough power to get out of the red. Once you have the new batteries charge before use and then check the charger t make sure you are getting a good output to charge the batteries Hope this helps
Apr 20, 2011 | Electric Mobility Mobility Electric Power...
I have a problem in my mobile nokia 6300.when i keep my mobile in charging it is not responding anything now what to do to charge my mobile phone??where i go for this problem??in which nokia center for my...
1.change chager and cheak
2. cheakelectrical pulg inpoin
3. ifnot slove change the nokiaphone chageing pin inside the phone
4.go to nearest NOKIA CARE
Aug 06, 2010 | Nokia 6300 Cell Phone
I have problem with w850 charging when mobile
phone software is corrupt tutorial on how to flash new software to the phone here: http://forums.se-nse.net/topic/16148-tutorial-flashinggdfs-operationsuploading-files-with-xs/
May 18, 2010 | Sony Ericsson W850i Cellular Phone
It will not turnm with out the chager and it is chager all the way
Dear, you must change your battery, i mean get a new battery and then charge it. So after it charge unplug charger and turn on the phone.
Thank you
May 16, 2010 | Samsung FOR SAMSUNG INSTINCT S30 M810...
Motorrokr E6 "Mobile not getting connected to PC"
USB cable is connected between PC and Mobile, Charging is happening. Modem drivers installed. Mobile phone is displayed having Sychronising, phone book, calendar, text message, multimedia studio. On this "initialisation....please wait" is displayed and after some time it displays "mobile not connected".
Jan 11, 2009 | Motorola Mobility ROKR E6 Smartphone
Internet connection
to : sonu006
did the connection between your pc and your mobile phone ok? the link should be ok first. then try to run the cd/dvd of your isp in your place.
to: marianne biskeborn
you should enable the popup blocker in your ie. just right click internet explorer select properties under privacy tab click block popups. if its doesn't work, format your pc and reinstall windows os.
Apr 01, 2008 | Dell Dimension 3000 PC Desktop
Nokia 2600 Logo
139 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
