Question about Dual Car Audio & Video
Dual 1228 wiring
I would like info about wiring for dual 1228 THANKS
  • leone C
    leone C Jan 01, 2017
    What's a Dual.
  • 188 Answers
SOURCE: 694708-225 Intel dual CPU Motherboard
pls provide some more deyails-like
1-ur computer brand
2-model no (on cpu chesse)
i m sure i can help u///
u can mail me
best regards & best of luck..
Posted on Oct 12, 2007
  • 624 Answers
SOURCE: how should i wire 2 dual 2ohm subs to this amp?
If you wire them in parallel you will have a 1 ohm load. wire them in series and you have a 4 ohm load.
The 4 ohm load is much safer to run.
Posted on Jun 16, 2008
  • 15935 Answers
SOURCE: How do you wire up 2 4 ohm dual voicecoil subwoofers for 1 ohm?
Both + on Both Subs to + Terminal on amplifier.
Both - on Both Subs to - Terminal on amplifier.
Posted on Jan 15, 2009
  • 59 Answers
SOURCE: Viking dual fuel range wiring
You will need a neutral, ground and 2 wires carrying 120V each
Posted on Mar 11, 2009
  • 358 Answers
SOURCE: how to wire motor to dual run capacitor
The easiest way to do it is to get a capacitor just for the fan motor (in the motor tag you can read what size cap. you need , maybe 5uf or 7.5 uf) and put the two brown wires on each side of the capacitor and the lines (probably white and black) to the contactor.
Posted on Sep 27, 2009
Installing sterio
Buy an installation kit to ensure proper connections...
Also, don't buy a DUAL deck...junk
Jan 03, 2014 | 1986 Mercury Grand Marquis
Wire diagram for subwoofers
need more info,what ohm load are spkrs? are they single voice coil or dual? if dual what ohm dual 2 or dual 4? what amp are you planning to use? stereo amp or mono block? if mono block what make and model? what style box are you using,sealed or ported?
Jan 09, 2013 | MA Audio MA 1200XL Car Subwoofer
I have a leisure rangemaster 110 dual fuel cooker. The auto timer has gone wrong. How can I bypass this timer
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me
Feb 12, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
How to connect dual vouice coil to amp
Hey well your gonna need to give more info. is the sub dual 2ohm dual 4ohm. if you have a dual 2 ohm you wire one + to one- (like a jumper wire)and then your other +.- go to your amp as 4ohms, if you have a dual 4ohm model and your amp can handel 2ohm stereo then wire your +to+ to +on the amp and the same for your -. it will bring a 4ohms to 2 ohms by connecting pos. to pos. and neg. then to your amp.
Jan 18, 2010 | Kicker CVR12 Car Subwoofer
Need wiring schematic for output wiring.
Black is ground, yellow is constant power, red is switched power (only has juice when vehicle is on) dual grey, dual white, dual etc, are speakers, and blue is remote accessories like and amp or eq
May 17, 2009 | Clarion ARX6470
What is the difference in a dual 2 ohm sub and a dual 4 ohm sub?
Dual 2 ohm sub can be wired to achieve a 1 or 4 ohm load.
Dual 4 ohm sub can be wired to achieve a 2 or 8 ohm load.
Usually no difference in Theile Small Parameters.... Only wiring configuration - to get the most power out of your amplifier.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Dec 27, 2008 | Viking 48" 6 Burner, Grill Professional...
Dual 1228 turntable platter not spinning, the motor will not turn
If the motor is not spinnig then it is probably seized. These motors are very robust and rarely need replacement parts. Remove both the top and bottom bearings, clean shaft and bearings with solvent and then fill bearings with light machine oil. The bearings have a sponge inside which will soak up lots of oil for years of trouble free use. Once reassembled, tap the bottom bearing while the motor is spinnig and the bearings will centre themselves. If the idler and it's mechanism is working ok as well then you should feel lots of torque from the from the platter when it is spinning.
Dec 19, 2008 | Audio Players & Recorders
Car Audio & Video Logo
47 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
