Where I can get info for Dual 1228 motor wiring
2 Suggested Answers
  • 6 Answers
SOURCE: Dual 1228 turntable platter not spinning, the motor will not turn
If the motor is not spinnig then it is probably seized. These motors are very robust and rarely need replacement parts. Remove both the top and bottom bearings, clean shaft and bearings with solvent and then fill bearings with light machine oil. The bearings have a sponge inside which will soak up lots of oil for years of trouble free use. Once reassembled, tap the bottom bearing while the motor is spinnig and the bearings will centre themselves. If the idler and it's mechanism is working ok as well then you should feel lots of torque from the from the platter when it is spinning.
Posted on Oct 27, 2009
Motor drive grommet (black rubber)
Have you tried getting in touch with the manufacturer or any of their dealers?
Should you need -
HEADQUARTER
Elna International Corp. SA
icon_mail.gif Ch. du Champ-des-Filles 19
1228 Plan-les-Ouates
Switzerland
icon_mobile.gif +41 22 884 86 66
icon_printer.gif +41 22 794 95 40
icon_mail_back.gif info@elna.com
icon_home.gif http://www.elna.com/
You can also try getting in touch with dealers or country representative here.
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 08, 2008 | Elna Heirloom Edition 6005
How do I check the controller
hi,, that means
4,1 CURRENT SENSE FAULT current sense fault 1. Short in motor or in motor wiring.
2. Controller failure. *
You can send me the controller for free testing , you only pay the return postage...
Regards
Rob
www.gewizrepairs.co.uk
May 08, 2014 | Pride Celebrity Xl 4 Wheel Scooter
Installing sterio
Buy an installation kit to ensure proper connections...
Also, don't buy a DUAL deck...junk
Jan 03, 2014 | 1986 Mercury Grand Marquis
W 1228 romb batt
This suggests that the internal battery needs replacing.
Jul 18, 2013 | Dell POWEREDGE 2900 Server
Just got a xd 1228 cd recever for my van and dont want to work
try connecting ur power wire to ur remote one worked me for
Aug 12, 2012 | Ford Econoline Cargo Cars & Trucks
DUAL VOLTAGE WIRED FOR 460V AS FOLOW,(4+7)D (5+8)E (6+9)F.NEED 230 APPLICATION, SHOWS 4-4 5-5 6-6 L1-7 L2-8 L3-9.THIS MOTOR HAS A BOARD WITH TERMINAL MARKED 1,2,3,4,5,6,D,E,F,DO NOT UNDERSTAND HOW TO MOVE...
Hi; usually the conversion info. is on the backside of the cover You removed.If not try looking on the DATA plate on the motor itself...elsewise call a supply house sometimes they can pull up info on Your motor. Sometimes motors are wired a little different depending on the manufacturer...
Jan 20, 2010 | Heating & Cooling
The one fan willl not come on but both will when motor is hot
I'm not familiar with your particular car, but this info may be of some help to you...
Dual fan cars work in a few ways:
1) Some only use one fan during normal cooling, and turn on the second either when the temperature reaches a certain level, and/or when the air conditioning is running.
2) Some use both fans for normal cooling, but at least one of the fans have a dual-speed motor. Generally only one has dual-speed motor, which operates at low speed during normal cooling cycles, and operates at high speed at a predetermined temperature, and/or when the air conditioning is running.
Based on this, it's possible that your system is working correctly, or you have the chance that your low speed portion of the cooling system is not functioning. Check the wires going to the fans. If there are only two wires, then it's a single speed fan. If there are three wires, it's a dual speed fan.
Based on that information, you should be able to determine if your system is working correctly or not.
Dec 13, 2009 | 1989 Honda Accord 4 Door
Dec 19, 2008 | Audio Players & Recorders
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
