Question about Hasbro Playskool Kota and Pals Monty T-rex In Box Dinosaur
Kota Triceratops tail does not wag. How do I fix. It will start to wag for a second, then stop. It's makes loud noises like it's trying to wag but doesnt. Can I fix this or get a replacement tail?
  • 99 Answers
SOURCE: 2004 Kia Rio Won't Start Clicking Noise Battery is GOOD
Sounds like the starter.
Posted on Jan 22, 2009
  • 73 Answers
SOURCE: my 01 tahoe is making a very loud ticking noise
could be that your oil pump is clogged. your ticking it probably your valves starving for oil. Alot of times your oil will be fine but your oil pump will get clogged and cause the iol to take time to get to rhe valves
Posted on Feb 23, 2009
ourhowse
  • 2007 Answers
SOURCE: when i try to start it makes a loud grinding
Either your starter bendix is worn out or the ring gear. Better hope for the starter. You'll have to remove the starter and inspect the ring gear, and the gear on your starter, and remove/replace accordingly.
Posted on Jan 08, 2010
  • 11 Answers
SOURCE: We have a robot puppy dog with no bone and no instructions.
Perhaps you could print out instructions from: http://www.hasbro.com/common/instruct/67323.pdf
You could also order a new bone* from: http://www.hasbro.com/customer-service/orderform.cfm?sku=75050 (*US residents only)
Posted on Dec 23, 2010
emissionwiz
  • 77499 Answers
SOURCE: 1995 GMC SONOMA makes a loud sqeaking noise when i take off in the first to third gear, after third gear it stops, but when i get to a stop sighn it starts all back over, loud noise.
This type of noise is likely to be a universal joint that is worn out in the drive line. have a shop put it on a lift and inspect the joints.
Posted on Jun 06, 2012
How can I fix the tail of the playskool Kota triceratops?
If you can open Kota up (remove the fabric & unscrew whatever pieces),
you might be lucky enough to unjam it, or to move & re-align the gears.
There may be a spring that pushes one or both of the gears together that
may need to be checked too. If the gear teeth are OK but some other
part is broken, you can use 2-part epoxy from Walmart, Michaels, etc.
to fix it. Superglue will not work as it is too weak & brittle.
If the teeth on the gears are stripped, it will be tough. You can try rebuilding
the teeth with 2-part epoxy PUTTY (not glue) or 2-part plumbers putty from
Osh, Home Depot, or Michaels (Mighty Putty). and it may break again,
It might be easiest to call the company and ask about repairs and/or
replacement parts. Good luck!
Dec 01, 2016 | The Toys
How to fix my kota triceratops neck?
New you tube video 2:50 min video called Kota dinosaur
broken/hanging neck repair
Jan 16, 2016 | Hasbro Playskool Kota and Pals Stompers -...
How can I get an instruction manual for Playskool Kota dinosaur
Hasbro has the instructions and replacement parts for many of the Playskool toys on their support site, http://www.hasbro.com/site-map.cfm . The instructions for the Kota the Triceratops are available here: http://www.hasbro.com/common/documents/dad2af771c4311ddbd0b0800200c9a66/61EED7975056900B10DED12F214D6B3E.pdf . The instructions for the Kota and Pals Ankylosaurus are here: http://www.hasbro.com/common/documents/dad2af771c4311ddbd0b0800200c9a66/F235292B5056900B10B29E652C4640C1.pdf . However, they do not have any parts for the Kota and Pals set. You may find the leaf available in an internet auction.
I hope this helps.
May 01, 2014 | Hasbro Playskool Kota and Pals Monty T-rex...
Mod: kuds30ixss6 - Making a loud noise
You are going to have to remove the spray bars and the filter at the top of the pump housing to see if something is stuck in the pump
Jan 06, 2014 | KitchenAid Dishwashers
My Kota Triceratops's neck is broken and she can not sing anymore. Still blinks, moves horns, wags tail and open and closes her mouth. No sound
The neck is not moving up it just stays down while he talks, blinks, and looks side to side;
any solutions?
May 03, 2011 | Toys
My air hogs helix 360 is bobbing front and back how do i fix this?
No this wobble is not caused by the tail motor. i have had 3 that have all done the same thing. The fix is simple. The tail would cause it to go back and forth like it is turning back and forth with rudder. When he says bobbing he is talking about a oval shaped motion that the heli does while hovering. looks like its rocking front to back. tail wag is different and has to do with gyro over sensitivity. To fix: Look at the flybar and check for even flybar paddles (if looking down the flybar make sure one is not angled differently than the other) you can twist them a little to manipulate them. #2 the small extensions connecting the flybar to the links may be bent up or down. Again, looking down the flybar make sure they are pretty level with one another (you can slightly bend them back but be gentle. #3 There is a pin connecting the flybar to the head that goes through. What happens is, after a few bang into things this can start to move out just a fraction of a mm. You will notice that the flybar can move back and forth like it should very easily but there is also a little play rocking it the other way that it is not supposed to go. this amount will be very small but plenty to adversely affect the heli. take a pair of needle nose pliers and carefulle push that pin in just a touch until the flybar tightens enough to stop the movement. Be sure its not too tight so it takes away from the easy movement the flybar is supposed to have. I 100% promise its not the tail motor.
Feb 18, 2011 | Spinmaster Air Hogs Helix 360 Helicopter
My Airhogs Helix 360 will not hold a stable hover. It continually rocks back and forth without any controller input. This occurs even after a stable hand release. When doing a hand release, the rocking...
vlad that is tail wag. he is not talking about that. To fix: Look at the flybar and check for even flybar paddles (if looking down the flybar make sure one is not angled differently than the other) you can twist them a little to manipulate them. #2 the small extensions connecting the flybar to the links may be bent up or down. Again, looking down the flybar make sure they are pretty level with one another (you can slightly bend them back but be gentle. #3 There is a pin connecting the flybar to the head that goes through. What happens is, after a few bang into things this can start to move out just a fraction of a mm. You will notice that the flybar can move back and forth like it should very easily but there is also a little play rocking it the other way that it is not supposed to go. this amount will be very small but plenty to adversely affect the heli. take a pair of needle nose pliers and carefulle push that pin in just a touch until the flybar tightens enough to stop the movement. Be sure its not too tight so it takes away from the easy movement the flybar is supposed to have. I 100% promise its not the tail motor.
Need a user guide for kota
Dec 15, 2010 | Hasbro Playskool Kota and Pals Stompers -...
Can you get a replacement leaf for the big Kota
He can eat anything its not like the leaf has a magnet or anything if you put something in his mouth like your hand even, there is a little button/switch whatever on the roof of his mouth that causes him to eat
Jul 23, 2010 | Playskool Toys
GE JVM1650 Microwave Making Loud Noise
hello Frank. Sorry to tell you that the magnetron is going bad and making that terrible noise. Since the inside of a microwave, even unplugged has up to 2000 residual and deadly volts of electricity I recommend either calling a pro or replacing the unit.
Jul 12, 2009 | Microwave Ovens
Hasbro Playskool Kota and Pals Monty T-rex In Box Dinosaur Logo
73 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
