Question about Amerimark Heating & Cooling
The switch on the back of my iheater was lost in a move. Where do I purchase a new one?
2 Suggested Answers
joelwilcox
  • 1274 Answers
SOURCE: have a ezbookpc that came with the purchase of a iheater it does not have name on it as the tag on the back has been removed need a usef manual for it if possable
where did you purchase the iheater? you could always ask them, please take a pic and upload to an image hosting site such as photobucket that could help us identify the type of laptop
Posted on Jul 01, 2012
Can the on/off switch be replaced? Ours broke off the back of the unit. This is an iHeater 1500.
Unplug the unit, Take out the old switch (You may need to open up the unit to get behind the switch to remove) and bring it to a hardware store or similar to match up. They normally have 2 connectors. Easy to do. Good luck!
Dec 21, 2016 | Washing Machines
My iheater (iH1500) seems to be missing a fusable link located in the back center of the unit. Can I get one to replace it. The unit doesn't power up.
If you believe it is not powering up because of a blown or missing fusible link, you can simply BYPASS the fusible link with a (large) piece of wire, briefly turning the power on to test the unit. If the unit powers up with the bypass wire (and it does not blow the fuse or breaker to that outlet)... leave the bypass wire there!
May 14, 2015 | IHeater 1500 Advanced Infrared Heater...
Iheater 1500 I bought a replacement switch but failed to see how the install should be when I yanked out the old broken on. There are 4 section 2 white & 2 black wires that need connected. What order
It is relative easy, check the switch contacts, you actually have two switches in one. Put the white on one "switch" the black on the other. You can check it with an ohm meter or continuity tester.
Nov 18, 2014 | Hardware & Accessories
I followed the instructions to a T. I turned my iHeater on using the--O switch located on the back. I adjusted the desired room temperature to 74 degrees. I adjusted the room size to Large. The iHeater...
I would read the customer reviews on this product , looks like nearly 70% of consumers are less than happy with this unit.
1500 watts is the units peak output, and drops to around 600 as it warms up. My hair blower puts out more power.
1500 watts is LESS than the output of a small element on your stove top. The real measure of heat is not watts, its BTUs and btus from gas are much cheaper than they are from electricity.
Nov 12, 2013 | IHeater 1500 Advanced Infrared Heater...
Have a ezbookpc that came with the purchase of a iheater it does not have name on it as the tag on the back has been removed need a usef manual for it if possable
Jun 30, 2012 | Computers & Internet
Have a new john deere walking sprinkler lost receipt it will not move foward i have moved the selecter switch from h to l nothing happens so how do you get the gear box opened up
If it is new ... take it back to the place you bought it ... see the clerk who took your $ ask them if they remember you purchasing the device on a particular day ... establish that is is a new device then ask for instruction on operating it or for an adjustment or parts to repair it.
May 05, 2011 | John Deere Gilmour Traveling Sprinkler -...
Feed switch came apart, seems to have lost spring out of wirewhip
sounds like you lost a spring i would just get a new gun
Jun 26, 2009 | Welding Tools
1989 mercury Grand Marquis A/C system
a factory workshop manual will help you with the problems
ac moving from cool to heat means that the ac compressor is cycling from the thermostast setting
if you have climate control in use , that indicates a problem climate control module
May 30, 2017 | 1989 Mercury Grand Marquis
Heating & Cooling Logo
26 people viewed this question
Top Amerimark Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you an Amerimark Heating and Cooling Expert? Answer questions, earn points and help others
