Question about Thermador Kitchen Ranges
How remove time/temp circuit board from Thermador electric range?
SOURCE: oven bake does not work properly
check the selector swich and thermostat.
Posted on Dec 07, 2008
bozcro
  • 867 Answers
SOURCE: Hotpoint electric range (B747C) cooks slow
heating element needs to be replaced
Posted on Nov 25, 2009
HarryHarley
  • 343 Answers
SOURCE: I'm having trouble with the lower heating element
Most of the time it the heating element.
(recheck your model number)
Here is a good source for replacement part
http://www.partstore.com/Content/CategoryPages/Kitchen-Cooktops.aspx
Or directly to GE
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=LANDINGPAGE&AppliancePart=Cooking%20Products
Posted on Dec 24, 2009
SOURCE: Fan works, but Oven stays at 100 degrees. Tried
On my C301 U, I found the brown connector on the right side of the oven control board P3-2 loose. It looked connected but while doing a shake test- Whoop, there it is. It is the sensor for the temp probe. If it's loose all the fans run all the time.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=C301U&productCategoryId=0124100&brandId=1085&brandDescription=THERMADOR&modelName=BUILT-IN-OVENS&diagramPageId=00014&componentDescription=WIRING%20DIAGRAM&documentId=U2500861&blt=06
Posted on May 23, 2010
  • 4 Answers
SOURCE: Presumed bad circuit board on my LG LRE30755ST electric range
You may wish to try removing and re-seting some of the connectors on the back of the control panel...worked for me when our oven and timers stopped working.....
Remove the sheet metal panel at the top of the back of the oven..three phillips screws....then slide the two blue ribbon, wire connectors out, and re-seat them a few times to get a good connection.
Try to un-seat and re-seat some of the others aswell...perhaps un-plug from the wall first....but make sure there is good connections....then re-plug in, and see what happens...
Posted on Aug 24, 2010
Oven won't keep temp.
I would try another control board. I have gotten 2 new ones before that were bad right out of the box! It happens all the time.
Dec 27, 2013 | GE Profile JGS968 Gas Kitchen Range
I can't read the oven temp. on the LED Panel of my Thermador RDF 30 Range. I've learned that the whole panel should have been replaced...but it is no longer available, and must be rebuilt. Is this...
I could not find a panel for your model.
We have used http://fixyourboard.com/ to repair control boards that were NLA.
Check with them to see what it would cost to rebuild the one you have.
Aug 03, 2011 | Thermador RDF30 Dual Fuel (Electric and...
Need to rebild clock board 14-33-347 from a thermador range
Your best bet is to replace the board. ive actually not heard of anyone rebuilding a control board. To rebuild that board your gonna need a understanding of what each component does. . Personally I dont think its worth attempting to do. I do know that the board is costly. So whast can suggest is that you contact the manufacturer and see what they can do for you. If the range is less than a year old, most likely they will replace the control board at no cost to you.
Feb 09, 2011 | Thermador REF30 Electric Kitchen Range
Thermador 30" range, gas top, electric oven. The display light (e.g. bake 425'F) is VERY dim. How can I fix / replace this?
You may want to send us the control board to see if we can rebuild it and save you some money compared to replacement. Best Regards, bruce www.fixyourboard.com
Jun 15, 2010 | Thermador RDF30 Dual Fuel (Electric and...
I had the same problem in December - I had to replace the circuit breaker and that solved the problem. My oven wouldn't go above 100 degrees in convection, bake and roast modes. Each of these modes are on a separate circuit so when one is bad, the others should work.
Jan 25, 2010 | Thermador C301U Electric Single Oven
Thermador Built-in oven model cm301
Same issue w/our Thermador CM301. F23 and F24 codes - BSH acts like they have never heard of the problem! Awful service. This should be reported to the Consumer Board.
Feb 19, 2008 | Thermador SC302T Electric Double Oven
Thermador oven
I had this happen and it was a result of a sensor melting during self cleaning. I just got this code again today.
Jan 23, 2008 | Thermador RDDS30 Dual Fuel (Electric and...
Kitchen Ranges Logo
Top Thermador Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
