I have the 125000 mister heater,where is the reset switch?
I HAVE A 125000 PROPANE REDDY HEATER THAT GETS WORM, BUT WANT GET HOTTER.
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 20, 2011 | Reddy HEATER RH125T 125,000-BTU...
How to winterize ? i have the jandy lrz model 125000 natural gas and what to know how to close down and winterize
turn off gas valve and blow water out with air then with RV antifreeze when you see antifreeze coming out its good see you tube video on pool closing
Oct 27, 2010 | Jandy Legacy LRZ 125000 BTU Millivolt...
How to winterize ?
There should be a drain plug on the bottom of the inlet/outlet header. Also, depending on where it is, you should remove the pressure switch and let it drain. Turn the gas valve off. When you blow out the return lines, it should remove the water that's in the heater, after the return lines are blown and plugged, you can then remove the heater drain plugs and pressure switch.
http://www.youtube.com/watch?v=0y7fJxq7g4o
I have reddy heater 125000 and it wont start
heatman101
Oct 23, 2010 | Reddy Heater RH125T Kerosene Forced Air...
My 7142 leaks
There are a few hose connections inside the unit related to the heater element. Water flows from the reservoir down into the unit, takes a turn into a tube with the heater element wrapped around it, then turns back up into the mister area. Any of the four connections (base to first elbow, elbow to heater tube, heater tube to second elbow or second elbow to base) could be leaking.
The white ring around the mister disk cracked on my unit, letting water leak out the bottom as you describe... Take a close look at that.
It's also possible the base itself is cracked somewhere... Look closely at the mister and reservoir areas of the base for cracks.
Dec 16, 2008 | Air-O-Swiss U7142 Humidifier
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
