Question about Oster Microwave Ovens
My Oster microwave won't heat ogg61403 - Oster Microwave Ovens
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: My Oster OM1201eovg microwave will turn on but it won't heat what I put in there. What's the problem?
Either the inverter which powers things or the Magnatron which in effect does the heating are bad.
If a fairly expensive unit it may be worth repair as these are of course two of the more expensive parts in the unit.
Posted on Sep 04, 2012
New microwave stopped working after 15 seconds
Possibly the fuse / breaker is tripped, usually all outlets in one room share same breaker. Check breakers (or fuses) or try outlet in differnt room. If the outlet has power, (plugin a lamp to check) and the microwave still does not work, take it back to store for replacement or refund.
May 11, 2013 | Oster OGG61403 1.4 Cubic-foot Digital...
Electrical burning smell
It is hard to tell what is burning, take it to the repair shop
Mar 12, 2013 | Oster OGG61403 Microwave Oven
Sep 04, 2012 | Microwave Ovens
Received for Christmas 2010. Worked great! Few nights ago, made something to eat, and it shut off. Light, clock, everything. After a few minutes, it came back on. Used it last night, same thing. But this...
The joys of purchasing items with a bought out warranty. Check the plug and contacts on the fuse.
You could either call a microwave repairer and pay for callout and repair or purchase a new one.
May 30, 2017 | Oster OGG61403 Microwave Oven
Microwave turns on, but does not cook. the light and the turntable work, and the digital butons and timer, but does not cook.
HI. Your symptoms are a strong indication Magnetron failure. This is the principal heating device, that is used to produce microwaves that , essentially, excite the water molecules in the food, thus, producing the heating effect. When this device fails, generally, the unit will run, but not heat. This device is very fragile, and can injure you if you are not qualified to handle this type of component. There is a High Voltage Capacitor, that is used to help provide the necessary current for optimal Magnetron operation. This capacitor must be discharged correctly. If not, you could risk serious injury, during the repair, if it is accidental touched.
The Magnetron is linked to a cut-off fuse. If the magnetron becomes unstable, this fuse will shut the device down. It is standard procedure to have this fuse test for continuity. If the fuse has blown, this will be the culprit. Replace the fuse. Now, if the fuse continues to show continuity, this will confirm that the Magnetron has failed. I would advise to inspect the Capacitor, and HV diode for visible burn marks, or swollen top(Cap).
Access can be ac hived to these parts by removing the outside cabinet screws. Once the screws are removed, the cover can be removed, as well. Once the cover is removed, the internal components will be exposed for testing, and visual inspections.
WARNING: IF YOU ARE NOT A QUALIFIED SERVICE TECH, THIS WILL NOT BE A NOVICE DO IT YOURSELF JOB. MICROWAVES ARE VERY DANGEROUS, AND CAN CAUSE SERIOUS INJURY. I RECOMMEND TO CALL FOR SERVICE, IF YOU ARE UNCOMFORTABLE WITH HANDLING THE CAPACITOR, OR MAGNETRON...
Apr 06, 2011 | Oster OGG61403 Microwave Oven
Theovenwon'tshutoffunlessthedoorisopened
Check/replace the door interlock switches.
Jan 29, 2011 | Oster OGG61403 Microwave Oven
How do you install the wave guide cover ? vdesai8850@gmail.com
Wave guide covers normally fix with one screw or plastic clip. They fit inside the cavity sometimes clip in and stop food particles contaminating the magnetron or aerial.
Dec 31, 2010 | Oster OGG61403 Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
ray gallant
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
