Question about Maytag Heating & Cooling
Maytag ABB2224DEW Freezer works fine, but refrigerator section has to be repeatedly manually defrosted turned off to keep working.
When it doesn't cool the outlet doesn't release cold air even though the compressor is working
  • Maytag Master
  • 14,584 Answers
Your defrost timer needs replacing, and possibly the defrost heating element. An engineer will carry these as spares.
Posted on Dec 29, 2016
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Maytag Wide by Side Freezer not working
open the freezer panel at the back of the freezer section and check the evaporator fan, it could have been burnt.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Freezer side works fine, Refrigerator side is too warm
Hello.
The leading problem when freezer works yet the refrig. section doesn't get cold is going to a problem with a automatic defrost system defect. Do ya see a bunch of frost inside of the freezer on the back wall?? if yes ya do see that frost build up ist defiently not defrosting and this tip i wrote covers what to check when it doesn't defrost http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Oct 04, 2011 | Jenn-Air JCD2389G Side by Side...
My jcd2389des freezer is working fine but the refrigerator isn't cooling properly
Hello Sharleen,
GENE
Oct 03, 2011 | Jenn-Air JCD2389G Side by Side...
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
Refrigerator not cooling-Freezer Coils Freeze Up & Don't Defrost
check the fan assembly theres not enough air flow going over the coils
Feb 11, 2010 | Maytag MBB2254G Bottom Freezer...
Maytag model MZD2766GEB: Freezer compartment seems to be working fine. Refrigerator section is too warm. Moving temperature selector is ineffective. Do not feel any cold air blowing into refrigerator...
I believe your Adaptive Defrost Control found inside the fresh food compartment and behind the control panel is failing you. The part number is 61005988 If not this the defrost heater and defrost thermostat may be the next likely cause. Thanks, Sea Breeze
Aug 27, 2009 | Maytag Refrigerators
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
On our maytag plus fridge, the freezer is working fine, however the refridgorator is not keeping cold
You may be having a defrost issue, when ice builds up in the back panel inside the freezer section it causes an air flow restriction to the frig side. You can try letting it defrost and if it starts cooling again it may be the defrost thermostat located on the heater.
Jul 30, 2008 | Maytag Refrigerators
Heating & Cooling Logo
Top Maytag Heating & Cooling Experts
Rick Johnson
Rick Johnson
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
