Question about Welding Tools
My fire power fp130 mig welder won't arc or weld. fan runs and wire feeds but does not weld. I thought it might be the rectifier but can the diodes be replaced? if so where can I find them?
    Top Expert:
  • 77,932 Answers
You can buy the diodes online, but you need the numbers off them and the rating.
Posted on Dec 29, 2016
I am having weak arc issues and will not weld at any of 5 settings. Any idea what my problem may be?
does the machine buzz a lot louder then usual if so you could have a diode gone on the welding rectifier if not check all connections even if the look good
Oct 26, 2013 | Lincoln Electric Lincoln Easy MIG 140...
Kende weld no arc
make sure your work-piece has a proper ground. and maybe check your gas connection. no leaks. maybe turn gas down.
Mar 27, 2013 | Welding Tools
How do you switch the polarity switch on the 115 farmhand versa-arc mig welder. trying to switch from mig to flux core wire.
Disconnect you ground clamp form the negative side pole and switch it to the positive pole, same for the gun disconnect the from the positive side and switch it to the negative pole.
Good luck.
Sep 07, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
Weld arc not stable. Wire feeds, good ground,
Arc blow could be the cause! Put your ground on the work piece and weld away from it. If you weld toward a ground clamp the magnetic forces will blow your arc around sometime. When taking a cert this simple mistake can make or break ya on your cap or reinforcement beads.
May 09, 2010 | Hobart Handler 140 Mig Welder
I have a firepower fp130 mig welder . I have been using 0.30 wire,can I use bigger wire in it,if so how do I adjust the welder for it
The only thing you need to do is change the tip to the 0.30, and feed the wire. If no 0.30 tip is included with the welder it just isn't designed for that wire. You will also need to flip your friction feed wheel at the box to match the diameter.
Mar 24, 2010 | Firepower 120 Amp MIG/FLUX Cored Welding...
I have a Lincoln Electric Power Mig 200 and I managed to get the frame of the welder touching the piece I was welding and I noticed it started to weld about half the time as though maybe half the rectifier...
I would guess that you are on the wrong track. Half of the diodes going out would cause problems 60 times per second, which would be too fast to notice. Unless the diodes all shorted and you're essentially running AC now, which is possible, but unlikely. When my wire feed "pushes" like that,it's usually because the tip is burnt or dirty and not making great contact with the wire. Try replacing the copper tip that the wire feeds through. If that doesn't fix it, look for a bad connection on the wire that runs from the diodes to the torch. Good luck.
Mar 21, 2010 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Mig Question
MIG stands for Metal Inert Gas welding, many times called Wire-feed.. Also referred as GMAW (Gas Metal Arc Welding). The "Metal" refers to the wire which is what is used to start the arc. It is shielded by inert gas and the feeding wire also acts as the filler rod. A semi-automatic process, it is fairly easy to learn and use.
Aug 27, 2008 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Welding Tools Logo
384 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
