Question about Miscellaneous
I need to find out which spa I have so I can get filers for it and shut off valves
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
There's usually always an information plate located somewhere near the access panel. This plate will tell you the serial number and model number as well as production dates etc.
Posted on Feb 03, 2017
Pool heater banging in spa mode
need more info is this dual equipment if so turn the pool heater off when in spa mode also do the opposite when in pool mode
Dec 26, 2013 | Hayward Pool & Spa
How to change the water filer on a rf4267hars 25.5 ft
You must shut the water valve to change the water filter. If you don't havewater valve near the fridge, shut the main water valve for few minutes. If you turn the water filter to change without shutting the water valve, lots of water flooring the fridge and you do lots of work to remove the water inside the fridge. Shut the water valve, and then replace the filter. Then turn the water valve.
Apr 02, 2013 | Samsung RF4267HARS 25.5 Cu. Ft. French...
I have an inground pool and elevated spa that overflows into the pool by waterfall. I have freeze protection which causes the pump to run in colder temps. I did not know that and thought I turned the pump...
sounds like without a key u need to jimmy the door open
going to have to cut the power to the pool pump motor
if running dry and wont shut off . it may burn out
then need to call a pool repair guy
one of those valves you mention is faulty
and to show you how the pool valves work
Mar 06, 2017 | Pool & Spa
When driving it shuts off will restart but shuts off again multiple times. Then will run but when you push on gas it has no power like fuel is cut off.
Many things can cause this, the most common problem may be a clooged fuel filer or a weak fuelpump, you should have a fuel pressure gauge installed to see the fuel pressure when is stalls, another common thing is the egr valve, sometimes carbon gets stuck in the valves and jkeeps on open a little causing stalling or lack of power, start with these two things and we will go from there, good luck, hope this is helpful.
Oct 28, 2010 | 1999 Chevrolet Blazer
How do I lower the water level in my pool? Show a diagram, so I can see what values I need to turn and adjust. My pool has a float mechanism and a drain fuction at the main control panel but I am not sure...
Their is no valve to turn the float valve need's to be lowered. If the level has been good and has just started to run high you may need to replace the float valve. At your house you will find a pipe coming off one of your hose bib's and running into the ground. This will be the pipe that has a valve to shut the leavler off.
Jan 21, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Why does the spa empty when the pump shuts off? just got a pool with an aqualink RS4 and no manual to look at. thanks
This problem can be caused by a couple things. the two most likely culprtits are either the absence of check valves and or incorrect actuator settings when the pump shuts down.
Your spa is most likely higher than the pool. You most likely have a spill over (waterfall) feature from the spa into the pool. This is so the spa water can be recirculated in pool mode. One of your actuator valves may be slightly off closed position in order to allow spill over in the spa, or you may have a dedicated overfill pipe in the circuit to feed water to spa in pool mode.
Whichever spill over piping you have set up, when the pump shuts down, water from the spa ( higher level than the pool) will backfeed through the overflow spa circuit, back through the pump and into the pool through either drain or return. Effectively rendering your spa level the same level as your pool.
To fix this problem, simply install check valves into the spa runs and as a secondary measure put one into the pool return run ( the run that feeds water to pool).
This will insure that when the pump shuts down, no matter which position the valve actuators may be set, water can not back feed through the pump circuit from spa to pool.
Jul 15, 2009 | Water Pik Aqualink Rs4 Package - Pool and...
Brand new 2009 model 8111 can't get filer to run
There is an air lock, so it seems. Leave filter off, on top of filter is a valve to let air escape. Keep this open until you get a stady stream of water from oulet, then close. Start pump. Not being a smart ****, besure that the water flow is correct. Skimmer to inlet side, return to pool.
Jun 09, 2009 | Intex Automatic Salt Water System for ...
No jet flow hot springs highlife 1990
you might have an air lock, when you first start filling the spa, start the water running in the skimmer first. that should force air out of the pump and should pick up prime right away. if not, you may have a valve problem.
Mar 30, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Miscellaneous Logo
23 people viewed this question
Top Miscellaneous Experts
Randy Hughes
Randy Hughes
Joey Gammon
Doug Davis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
