Question about The Watches
My watch is tries to download the course I have always downloaded but fails to. The watch is charged.
Why isn't battery recharging in sunlight?
Failure to recharge completely could be a sign of a failing battery.
Dec 03, 2015 | Casio Mens PAG240-1CR Pathfinder Triple...
Can't locate sattelites on golf course
When you try to locate satellites it could take some minutes before the device find enough to calculate the location. Please give it some time. Also make sure the watch is charged.
Mar 16, 2015 | Garmin Approach S1 Wrist Watch green
Casio pathfinder battery operated watch keeps blanking out display?
Your watch is solar powered, so I think it isn't charged lately. At a low charge, the watch goes into saving mode by switching off the display (while keeping the time, date, etc.). To charge the watch leave it in a brightly lit spot for a day or two. That should be enough to make the watch function as normal again.
For more information, you can download the manual of your watch here (direct download link):
Timepieces Watches Manuals CASIO
Jun 11, 2014 | Casio Pathfinder PAG60-1AV Watch
How do you set the watch for Central Time zone?
hi there wave ceptor watches vary wildly in their instructions, try going to www.casio.co.uk you will need the module number (found on the back plate) go to support and download the PDF manual (very easy to use), you may have to download adobe reader free of charge at www.adobe.com to read PDF files. good luck
Aug 08, 2009 | Casio Wave Ceptor Atomic Watch, WVA105HA...
Where can I get an owner's manual for a Sector 133 Chrono Alarm watch?
As there is no manual downloads possible for SECTOR watches, the only solution is to contact SECTOR directly. Of course you can browse all the internet, but I'm quite sure direct contact will save you nerves, time and money.
Here is the link:
http://www.watchservicecenter.it/
Rate, please.
Jul 22, 2009 | Sector Watches
Internal battery seems to have no power
Battery in your watch is called ''CAPACITOR'' and it gets charged by light. The best source, of course, is sunlight and the worst is ordinary lamp.
By placing your watch for a few hours in a sunny window should keep your watch going for about 5 - 7 days.
As this is not happening, you need to replace capacitor. After doing that your watch will keep working and charging as brand new.
Capacitor replacement is not complicated job and any decent watchmaker can do it for you.
Do not forget to rate, please.
Feb 24, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Download a user guide for the Casio waveceptor watch model 2758
depending on what kind of watch you have you could always google the company to find the model, then look up an online manual
Jul 04, 2008 | Watches
Date setting on Citizen 0510 chronograph
Try this method. Set the date until it reads a couple of days in the past and then set the correct time. Of course do not touch your date or time settings between the hours of 9PM-1AM. Wait until the next day, then move the hour hand forward until you reach the current date with the correct time.
Jan 09, 2008 | Citizen Eco-Drive BL5184-56L Wrist Watch
Casio Oceanus Atomic Setting
I also have an OCW-M700 and found the instructions that you download from the casio website good and perhaps easier to follow than the booklet, still does need some patience and but worth it in the end because it is a great watch. The manual time/date setting can be done fairly easily once you are in 'Timekeeping mode' (page 4, bottom right). The applicable download is operation guide 4749. Good luck. Also, you probably dont want to know this but for others out there - they sell for around 600US$ in taiwan if you can find a shop that stocks the casio upper range, taipei airport normally has stock at duty free.
Jan 05, 2008 | Watches
Watches Logo
Top The Watches Experts
D. E. Hev
John mullen
vince
Are you a The Watch Expert? Answer questions, earn points and help others
