Question about Thermador Kitchen Ranges
Thermador kitchen range..... Does top get removed by prying front edge with screwdriver?
SOURCE: Thermador wcggcv30 gas cooktop - how to remove glass top
Remove the brass ring nuts and the screw from each of the burners and pull off the knobs, then lift up the glass cooktop; no need to remove the three screws around the perimeter or even take out the box.
Posted on Dec 14, 2007
SOURCE: LP conversion for Thermador 4 burner range top
I have a Thermadore 6 burner gas cooktop PCG366E purchased January 08. I purchased the LP conversion kit, they only make one kit for all models. The instructions included with the kit were written for an older model and have not been updated by Thermador. The gas regulator is located next to gas inlet pipe. You have to get at it from above. Remove the 2 star burners over that side of the cooktop. You will need a 20mm socket to remove the nut at the center of the star burner. Lift it off and disconnect the wire to the ignitor ( You need to push on the spring lock in order to seperate the the connector terminal). Remove the stainless steel pan and then remove the metal pan underneath ( you will need a Torxs bit for this screw or vise grips). You should now see the regulator. At the top of the regulator is a cap with the letters NG visible. Twist this a 1/4 turn ccw, lift up and turn over to expose the letters LP reinsert. The regulator is now ready. You will need to replace the orifice tips at each burner. Use a 7mm socket with an extension. Put a piece of tape in the socket to hold the orifice in place while you insert it. You also need to adjust the valves. You must pull off the knobs and and remove the trim bezel. If you look through the screw hole on the right you will see a screw head (bypass screw). Insert long skinny flat blade screwdriver through the hole and turn the screw CW all the way (about 1/4 to 1/2 turn in my case). My cooktop had two burners with a low simmer feature, This devise is located in front of the bypass screw. It has a hole in it but does not align well with the head of the bypass screw and makes it difficult to turn the scew. Thats it, I hope this info has been helpful. I have not yet connected the propane therefore have not tested the unit but it should work.
Posted on Feb 27, 2008
SOURCE: Remove the top cover?
With the LP500/530 and SP110, turn the projector upside down and remove the 2 torx screws which are on one side. Pull the focus and zoom rings. Remove the front grill which is held by one screw. With the grill removed you should see 2 screws that holds the front cover. Now you should be able to unhinge the top cover, take care to gently remove the ribbon cable that connects the top control panel to the mainboard.
Posted on May 11, 2008
SOURCE: Fix rust spots by dispensure
Their are two spring clips in the front of the washer that need to be pushed in with screwdrivers and the top flips open.
Posted on May 26, 2009
Coleman37
  • 337 Answers
SOURCE: trying to fix drip on cold water. Removed screw
I don't know what type of faucet you have. If you try to pry start from the back of the faucet. That way if you mess up the chrome (or other finish) it won't be so obvious. And make sure the water is turned off.
Posted on Mar 10, 2010
Replace burner in ge JB850 model?
most have clips near the frond edge that you can release with a thin pry bar of screwdriver . then tilt top to access the elements
Feb 20, 2015 | GE Kitchen Ranges
Can the cooktop surface of my Kenmore gas range model 790.72903011 be removed
Most stove tops are removable for that very purpose.... after you remove the burners and the grills above the burners.... look for an edge and inch or inch and a half below the top... get something strong like a large screwdriver and place cloth over the tip to prevent scratching the stove top. there are VERY STRONG CLIPS holding the stove top to the stove, pry upward until the clips release. then slowly remove the spark igniter (TAKE A PICTURE WITH YOUR CELL TO REMEMBER HOW PUT BACK TOGETHER)
Jul 30, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
BROKEN RANGE GLASS ASSEMBLT REPLACEMENT
Third time today. Remove all burners ,everything you can remove from the glass top, then use two small screwdrivers as tyre levers go around the edge and the glass top will lift off.
Apr 17, 2014 | GE Kitchen Ranges
Do I have to take back of oven off to replace lower element of thermador range
No. It is done through the oven opening.
Disconnect power and remove the element from the front.
Jul 17, 2011 | Thermador RDF30 Dual Fuel (Electric and...
Need to remove module containing knobs and display. How? Have partially removed, but cannot detach from directly under cooktop. Looks like two more screw at top of module under edge of cooktop. how to lift...
Not familiar with the model your talking about, but,most range tops will open from the front, and hindge from the rear. You might have to carefully pry it open.
Mar 31, 2010 | Jenn-Air JES9800A Electric Kitchen Range
Gas range, can't remove bottom oven panel - frigidaire FGFB55ASD
It pulls out toward the back or the oven. I usually lift it up as high as I can before yanking on it. If it is stuck, try sliding 2 small screwdrivers in the screw holes for more yanking leverage. As a lats resort, pry it out from the front; you may damage the finish this way. Hope this helps!
Feb 04, 2009 | Stoves Kitchen Ranges
Cant get oven to work
hi Step 1: Take out the screws that hold the panels, and pull off the control knobs. On the control panel the knobs are friction-fit; pull them straight off. Some knobs may have setscrews in the base of the knobs; back out these screws using a screwdriver or Allen wrench and pull off the knobs.
Step 2: Remove the back service panel on the control panel by backing out a series of screws around the edge of the panel. To remove the front panel, take off the control knobs and remove a series of mounting screws that hold the decorative panel to the frame. These screws may be hidden by molding or trim; pry off the molding or trim with a screwdriver, or take out several screws.
Step 3: To gain access to the burner assemblies, remove the burner grates and then the top of the range. The entire range top should either lift up and off the range or open up and back on hinges. The oven door can usually be removed by pulling it straight up off the hinges on both sides of the door. Some hinges have a latch that must be unlocked before the door can be removed.
Step 4: If the surface light of the range burns out, remove retaining screws and panels as necessary to gain access to the bulb. Replace the burned-out bulb with a new one of the same type and wattage; check the ends of the old bulb for this information. Then replace any retaining panels.
Step 5: If the oven light burns out, unscrew it and remove it from the oven. Replace the burned-out bulb with a new one of the same wattage, made for oven use.
Nov 06, 2008 | Maytag MGR4452BDW / MGR4452BDQ /...
One burner will not work
Remove the brass burner tubes on each burner., they are holding down the range top.
The top is slid in a hindge in the rearand clipped down in the front, pull and lift at the same time( take some force) from the front, this will release the top.
Jan 13, 2008 | Thermador RDDS30 Dual Fuel (Electric and...
Dec 10, 2007 | Thermador PGR366 Gas Kitchen Range
Model RDSS30QW X-LO Burner Problem
remove 4 screws under the trim that surrounds the burner knob panel. They are on the underside and you will be looking straight up to see them.
Slide the trim down and off after removing the screws.
remove the burner grills and caps
remove the 4 brass venturis and you will then be able to lift the cooktop
the valves are easy to get to
May 10, 2007 | Thermador RDDS30 Dual Fuel (Electric and...
Kitchen Ranges Logo
32 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
