My boss Leonel I have a coding ir6000s code is E000602 0004 I you help me
4 Suggested Answers
SOURCE: canon ir6000 error codes E000061-0001..
error E061 poblem
Posted on Dec 02, 2008
randula7
  • 78 Answers
SOURCE: my copier canon IR6000 shows error code E000061-0001. plaese help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} E061
Main Cause The laser shutter is faulty. The laser unit is faulty. The potential measurement
PCB is faulty. The DC controller PCB is faulty.
Mode of
Detection
0001 As the result of potential control, the drum surface potential (VL2)
of the white background is about 200 V (generating solid black images).
0002 The primary charging output used for print output and the drum
surface potential after laser output has been made are about 200 V
Posted on Sep 08, 2009
randula7
  • 78 Answers
SOURCE: error code e000020 in ir6000
E020
General condition
1) Is the developing assembly locking plate mounted correctly?
NO: Mount the plate correctly.
General condition
2) Is the shutter releasing member of the hopper mouth mounted correctly
to the developing assembly locking plate?
NO: It is likely that the inside of the hopper is clogged with toner. Remove
and then mount back the shutter releasing member to remove
the clog, or replace the hopper unit.
General condition, Developing assembly toner sensor (TS1)
3) Is the developing assembly adequately provided with toner?
YES: Check the developing assembly toner sensor.
General condition, Hopper toner sensor (TS2)
4) Is the hopper adequately provided with toner?
NO: Check the hopper toner sensor.
Hopper connector, Hopper supply motor (M10)
5) Is the connection of the hopper connector normal?
NO: Connect the connector securely.
YES: Check the hopper supply motor.
Posted on Oct 25, 2009
Canon ir6000 error code is morning E0061
Dear
The mode selection has problem, pl. check the laser unit shutter, LSU and DC controller PCB.
The above are the measure if the error code has no sub-error.
Thanks.
Jan 19, 2015 | Canon imageRUNNER 6000 Copier
How to solve this e000061-0001 error
Hi
The description for this error can be found here:
Error Codes Canon iR6000 Code E061 0001
and is the same for both the IR5000 and IR6000. There is a link on this page as well to download the full service manual for the model displayed, which should enable you to solve the problem.
On the right at the top of the page you can change the error code you are looking for to get a quick reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
How to fix error e000001-0000 for canon ir6000
You can try to reset error code in service mode, but if the error persist after clear, you need to rectify the problem and replace fault component which is fairly fixing easy to do.
The problem can be in thermistor, sub thermistor or dc controller pcb, or ... call service!
To reset error code:
while ready to copy/showing the error code:
1) Press the user mode key ( * ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( * ).
Choose: COPIER>FUNCTION>CLEAR>ERR
Turn off and back on the copier.
Jul 30, 2014 | Canon Imagepass L1 Print Controller For...
Error e350 canon ir 6000
pls help canon ir6000 error E350-3000 solved the problems
Jun 27, 2012 | Canon Service Manual For Ir 6000
Ir6000 error code e246-0002
well seems like Your copier print board is faulty or some loose wiring. also posible if some fault in counter pcb
you need to send it back for servicing to the manufacturer
hope it helps, thanks
Jan 11, 2011 | Canon imageRUNNER 400S Copier
Getting a problem with a canon ir 6000 error code E 350-001
ji guys I need ur help, I've error code on cannon ir6000 "000732-0001", please help me send to my mail ahlalrasyid@yahoo.com. ty
Feb 16, 2010 | Canon Office Equipment & Supplies
Error code e000020 in ir6000
E020
General condition
General condition
Oct 25, 2009 | Canon imageRUNNER 7200 Copier
I forgot my security code
i forgot my nokia 5200 security code ....please help me..please my imei number is 358659017768392 ....please boss help me... my email address is himel55@yahoo.com So Boss i am waiting for your Mail... Thanks
Oct 31, 2008 | Nokia 5200 Cellular Phone
15 people viewed this question
k24674
jasbo
jasbo
