Bonair cooler motor sometimes hard to start need to push start
3 Suggested Answers
  • 1456 Answers
SOURCE: I have a bonaire VSM65
Check the Room Thermostat Temperature Setting: Set the thermostat to at least 5 degrees below room temperature.
Check that the Room Thermostat is set to "Cool" not "Off" or "Heat". If the thermostat is not set to "cool" it is simply turning off your A/C.
Check that electricity is on for the equipment. Check all switches and controls, including service switches, including outside by the compressor, inside at the air handler, and fuses or circuit breakers in the electrical panel.
For example, condensate spilling into an overflow pan that uses a sensor switch can be enough to shut down your air conditioner. There are several switches and controls, both manual and automatic that can leave an air conditioner or heat pump turned "off" such as a blower compartment door interlock safety switch, an electric motor overload or overheat switches, and a condensate tray spillage detector switch.
Go to AC HEAT PUMP CONTROL AND SWITCHES to be sure you have found and checked every manual or automatic electrical switch on the system. A bad or failed starter capacitor could also be leaving your system shut down, failing to start a blower, fan, or compressor motor.
If the air conditioning system is still not working, or if the A/C system is running but cool air is not coming out of the supply registers you probably need to call a service technician.
Posted on Jan 30, 2011
SOURCE: Our Bonaire Evap Cooler stopped after power failure
you need to turn off power supply to unit that works ok and leave other unit switched on and code it and test it then switch other unit back on
Posted on Jan 30, 2012
New fan motor gets hot and stops after an hour have new computer
Sounds wired wrong, possibly wrong wires on capacitor.(if there is one of course) need to have wuring schematics and make sure its wired right. Hopefully its the right motor!!
Dec 22, 2016 | Heating & Cooling
My Bonaire evap cooler keeps tripping the fuse when I turn it on
there is an electrical short in the unit that is causing the fuse / breaker to trip
could be insulation, moisture in a junction connection or failing motor
Call in an accredited electrician to find / fix the fault
Mar 12, 2016 | Dryers
Bonair Evap Wont turn on after power failure
Hi bud do youself a favour before anything else take the main motor out and send it in to a reputable electrical repair co such as dynamic electrical in Benoni or look up a similar co near you and make sure that your system has not been hit bye lightning or a power surge from the supplier first I do own a Co that specialises in evap coolers and from previous knowledge a lot of the new systems have 12V inverters and if there has been a storm and you havnt diconnected your unit the PCs and motors are more than likely fried
Feb 17, 2014 | Mastercool 67471 Evaporative Cooler Air...
Bonaire vulcan evaporative air conditioner
check your filter for dirts, clean or change it, check your evaporator and condenser coil and clean....
Jan 29, 2014 | Heating & Cooling
I have a bonaire evap system cant get it to come on have changed batteries and reset it still nothing happens the remote is called bonaire comfort control have recently brought the house and cant find an...
Remotes are a pain. Can you get into the unit to see the control box? You need to see if the unit has power. If its new enough it will have some diognostic lights so you can see if it has power. Without that its hard to diognose. Unit Model number is also helpfull. if it looks like the one on this picture it will be etched into a badge on one of the corner pillars. if its a plastic unit it will be on a sticker inside the unit
Feb 24, 2011 | Mastercool 67471 Evaporative Cooler Air...
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
