Question about Cell Phones
Finding my flieght - Cell Phones
I lost my phone can i find it after battery has died?
no of course not, it has no power to phone home. You will have to wait until someone finds it and charges it up.
Jan 17, 2016 | Samsung Galaxy Cell Phones
Tip
Finding a word in Word
Tips for using Find in Word
What if you wanted to find a specific word, in Word? You know, you are looking for the word ‘know’ but you keep getting other words, too, like knowledge, known, acknowledge, knowable, etc.
You may say, “I always want to find a whole word; what’s the deal here?” Well … the deal is that Find will find everything that contains the word for which you are searching, as mentioned above.
A whole word, to Office and Word, is a group of characters surrounded by punctuation or spaces.
Word has a special function in Find, called ‘Find whole words only’ and it can help reduce the number of false hits. If you open the Find feature (Ctrl-F), and click the More button, you will find (no pun intended) this feature.
Okay, so to see the difference, search for the word ‘know’ in the following sentence. “This sentence is a way to show that you know the difference between education and knowledge.”
There is only one appearance of the word ‘know’ within the text; searching without the 'Find whole words only' option would actually find 2 matches. The other match comes as part of the front-end of the last word of the sentence, which is ‘knowledge.’
Before you go and use this option, understand that it will not find plurals and return them with your search results.
Searching for the word ‘know’ in the following sentence will not produce any matches: "It is not clear that he knows what this means."
on Mar 26, 2010 | Computers & Internet
User profile service failed log on.
Open in safe mode. Close help box.
enter regedit in search bar find HKEY_LOCAL_MACHINE
find;
SOFTWARE
MICROSOFT
WINDOWS NT
CURRENT VERSION
PROFILE LIST
hit +
find file * 1001. Re name it as *1001.ba
Find *.1001.bak rename as 1001 without .bak
Rename *.1001.ba to *.1001.bak
Find in right panel REFCount, change to 0 (ZERO)
Find State and change to 0
Close regedit and reboot.
Hope that helps.
Jan 18, 2015 | Toshiba Computers & Internet
Setup cannot find Office.en-us\dwtrig20.exe
Go the folder and open the file whichever your setup cannot find and then retry.for example if your setup cannot find dwtrig20.exe, find it in the setup folder and open it..then try installing it again. in most cases, the setup will not be able to find 2 files. open the two files whenever the setup cannot find them and then install.
this will surely work :)
Jun 08, 2011 | Computers & Internet
I can't find.
Can you please tell me what you are not able to find?
Is windows stating that it is not able to find the operating system?
or its not able to find the boot partition?
What is it or you not able to find???
Please be specific so that you get answers :D
Sam
Mar 26, 2011 | Computers & Internet
Im trying to find the fuel cut off switch on my cadillac devill 99 but i cant find it any where
There is no fuel cut off switch.Only Fords have a fuel cut off switch.If your vehicle is not starting you have to find out if it is lacking fuel or spark.Is your security light on?These are just some things to check to find out why it is not starting.Let me know what you find and help you find the problem.Good luck.
Oct 17, 2010 | 1999 Cadillac DeVille
Im using wep innovate web cam.but i cont find drivers.so its not working.where can i find drivers?
im using wep innovate web cam.but i cont find drivers.so its not working.where can i find drivers?
Jun 27, 2009 | Computers & Internet
Scanner frequencies
almost all frequencies are going digital encryted which will make finding frequencies hard to find
but there is a way to find frequencies
goto internet type in police scanner frequencies ( your city state or town) this will find the frequencies you need
Jun 14, 2008 | Uniden BC92XLT Handheld Scanner
Scanner error 6
Scanner errors are as follows for that model:
Scanner error #
1 = dark find
2 = LMW temp find
3 = bulb warm up from off
4 = bulb warm up from coarse
5 = cal label find
6 = doc original find
7 = LMW final find
8 = cal label find after scan
9 = cal label find prior to standby
10 = doc original find prior to standby
11 = bulb warm up from standby
I would see if there is an original on the flatbed glass (platen), or if something is obstructing the scanner view.
If the error persists, replace the scanner
assembly or the formatter pcb
Apr 22, 2008 | HP LaserJet 2840 All-In-One Printer
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
