A model number is better than a blade size :>)
Table Saw Parts : eReplacementParts.com
https://www.ereplacementparts.com > table-saw-parts-c-...
Need to fix your Table Saw? We have parts, diagrams, accessories and repair advice to help make your tool repairs easy.
Parts List - MasterCraft 055-6742-8 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual
MasterCraft 055-6742-8 Manual Online: Parts List. No. Description 1 Screw 2 Locking ring 3 ... 055-6742-8 Instruction Manual. Table saw with fold 'n' roll stand.
SOURCE: 10'' delta table saw manual
you might try Dewaltservicenet.com but you will need the model number and you might have to put the dash in between to get it to list the model. Let me know if you need more assistance and if you do I would also need this information.
SOURCE: can't get the handle of a mastercraft compound mitre saw to open
If you look on the left side of the saw near where you see that it pivots to go up and down. You will see some type of knob that you can pull out...you will need to push down on the saw handle to allow this to happen.
Hope this helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Testimonial: "thanks, got it working."
SOURCE: what kind of dado blade can I use on my craftsman
You have a 5/8" diameter arbor. You can use any dado blade that will fit. That said here's a few things to bear in mind.
8" diameter dado stacks are pretty standard for 10" contractor table saws. A dado stack is typically about 13/16" wide at most. It makes sense that the wider your blade is, the more power it takes to cut through the wood.
If you were to use the full width capacity of your Dado stack (13/16") a 10" diameter stack would bog down. A 8" stack has a faster rotation at the cutting edge because of its smaller radius. So, you don't bog down when you're making a wider cut if you use a smaller diameter.
If your machine was really underpowered, you could go down to a 6" stack which would cut your power requirements even more, but limits the depth of cut.
If this post was helpful, please vote. Thanks.
SOURCE: need the manual for my delta 10" table saw model
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams.
If you need more help come back.Post / thumbs / testimonial are welcome!
SOURCE: looking for 10 inch mastercraft table saw delux
I went to the Canadian Tire company website and found this number: 1-800-689-9928. I called and it turns out that it is the number for Mastercraft parts, but apparently the table saw (I have one too) is actually made by Porter Cable so don't be shocked when they transfer you to them.
Also, make sure you have the model (or Part) number. It's seven digits (mine is 55-6831-6) but when the roboline asks for it, just put in the first 6.
Hope this helps.
