Question about Dacor Ovens
Dacor Epicure wall oven -- lower latch is extended too far and door won't close. Help!
5 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Dacor Wall Oven Epicure EO130
I would call the store you bought it from or dacor as it is under factory warranty...
Posted on Aug 31, 2007
  • 30 Answers
SOURCE: Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Posted on Sep 22, 2008
SOURCE: Dacor MCS130 door latch will not retract
Same problem how do I fix it?
Posted on Feb 06, 2009
BADBOYJAY
  • 264 Answers
SOURCE: dacor wall oven model# MCS130S door won't close.
sorry this is a common fault with them you cant fix it i have tryed in the passed
Posted on Oct 17, 2012
Dacor Single Oven Epicure Millennia: There is a continuous clicking noise occurs when the oven is off. It almost sounds as if something is still running but it is not the fan nor is it the heating...
had this issue b4 the door latch was not communicating with the over control board? not sure in ur case but can check with multi meter
Jun 16, 2014 | Dacor Ovens
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
Dacor wall oven model# MCS130S door won't close.
Oct 15, 2012 | Dacor MCS130 Millennia Electric Single...
F8 alert. What does this mean? The clock and "cancel" buttons work, but no heating buttons work, and self-clean will not operate.
F8 code means your door latch assy needs to be replaced, them you have options:
1. Turn it off on the circuit braker
2. Replace the door latch.
It will continue to try to lock itself most likely, as door latch micro-switch logic is messed up.
Hope helps.
Jan 03, 2011 | Dacor ECD230 Epicure Electric Double Oven
Oven is locked cancel/secure bottom is not working turning the electrical box does not work.. what do we do
Try pressing in on the door while trying to release it. The friction of the latch may be keeping the latch from opening.
Nov 26, 2009 | Dacor ECS230 Epicure Electric Double Oven
Faulty oven door
This IS SO EASY !! I have the DACOR 48...no tools, 5 minutes and you are done! It took me 8 years of frustration and I fixed it TODAY !!
Just open the door, latch the small hook that binds the two hinges together. Next try to slowly close the door until resistance. Just when you think you might break something push up another 2 inches. Now lower the door , unhook the latch to seperate the hinges (latches) nad PRESTO a snug fit !!
Dec 19, 2007 | Dacor ECS127 Epicure Stainless Steel...
Aug 31, 2007 | Dacor Millennia MOV130 Electric Single...
SELF CLEANING DOES'T WORK
"F8" ERROR MESSAGE. This indicates a door latch failure.
Jun 25, 2007 | Dacor ECS130 Epicure Electric Single Oven
Ovens Logo
Top Dacor Ovens Experts
Vitaliy Gins
Vitaliy Gins
ashburton
Oloyede Monsuru
Are you a Dacor Oven Expert? Answer questions, earn points and help others
