Question about Maytag Washing Machines
Need the part number for a water pump for a Maytag Atlantis washer MAV200AWW. Thank you!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
Http://www.partswarehouse.com/Maytag-Appliance-Parts-for-Kitchen-and-Laundry-s/13502.htm?gclid=Cj0KEQiA4o3DBRCJsZqh8vWqt_8BEiQA2Fw0eSipMz4JMX_DgkuGBzXpoPpU___WCR2qmSPUlD2CR54aAsBU8P8HAQ#0
Posted on Dec 29, 2016
I have a Maytag Atlantis MAV6200AWW Washer agitates and spins. Water sometimes empties. Pump is fine spins freely and the impeller is fine. Could it be the belt ?
You will need to check for an article of clothing stuck between the basket and tub that may be partially blocking the drain hole.
Nov 22, 2012 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My maytag atlantis washing machine is working fine except it is not letting the water in, I have to do it manually, thank you Therese
You will need to replace the water valve. If you go to http://www.partselect.com/MultiModels.aspx?ModelNum=mav6000&searchTerm=img_52402&RefineSearch=0&imgMfg=Maytag and look at part #2. This is the part you will need. You can access it from the rear of the unit. You can also order the part for this site. Good luck
Dec 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
is the smell rubber or electrical? the pump could be seizing on it and burning the belt. check this out first.
Oct 25, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Warm water out when cold only button pressed. need part # for water solenoid
u can call any maytag store they can look up part but u can use the universal valve part no is 205613
Apr 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
We had the same problem and needed a new motor.
Apr 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
