Question about Samsung Dryers
What does blinking dryer light mean?
Samsung electric dryer. Drum will turn but dryer light blinks and cool down light stays on.
  • 13 Answers
If it is not heating check your element and or tstats
Posted on Dec 30, 2016
SOURCE: DLE2532W Dryer
I had the same problem. Really glad I came to this site. Had already tried to clean out the filter area. What really worked was unplugging and resetting the computer. Everything seem fine now.
Posted on Mar 30, 2008
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
  • 547 Answers
Posted on Feb 18, 2009
  • 10865 Answers
SOURCE: whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
If your dryer doesn't tumble, check these:
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Posted on May 21, 2009
SOURCE: lg tromm dryer electric cooling light staying on
I called LG after seeing this light as well and they say it's supposed to stay on and should "blink" at the end of the cycle. I've never remembered this light staying on in all the years of owning this machine but she (LG rep) said it was normal. Otherwise, if you've checked everything and it's not drying clothes, you may need to have your dryer serviced. :(
Posted on Dec 14, 2009
All lights are blinking on my fisher and paykl dryer ED56
it shows that machine is defective 1. may be the door lock switch may be defective 2. if the switch is ok means the motherboard of the unit is defective
Dec 25, 2013 | Fisher and Paykel DEGX1 Electric Dryer
Dryer sensor light blinking
press the End of Cycle button (hold down for 3 seconds, it should reset).
Oct 17, 2012 | Whirlpool GEW9200L Electric Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Lg tromm dryer electric cooling light staying on
I started researching on here because I was having the same problems with my LG dryer. (It also happens to be the same model.) I discovered the vent hose was kinked.
With the lights, the cycle it's on that blinks. When your dryer gets to the last 5 minutes, the "Cooling" light will blink and the "Drying" light will go off. If you have the "Wrinkle" setting on after the 5 minute cooling cycle, the wrinkle cycle will start and circular lights will show where the minutes normally are displayed and the Wrinkle light will blink.
Dec 02, 2009 | LG DLE2514 Electric Dryer
My xbox360 has a problem the off & on buttin is blinking red
Two blinking lights mean the CPU is overheating. Three lights mean the GPU (Graphics Processing unit) is overheating, Four lights means the A/V cable isn't hooked up. It it is the three lights, and you have never opened the xbox case, contact Microsoft and they will fix it for free.
Sep 24, 2009 | Whirlpool LER5636P Electric Dryer
LG DLE2512W Will not heat even after replacing Heating element.
there are a couple of thermal fuses also that could be blown inside the back check these also
Aug 25, 2009 | LG DLE2512W Electric Dryer
Cooling light
The cooling light should be blinking. Mine did the same thing. It ended up being the fuse that was going to the dryer from the circuit breaker itself. I ended up replacing the whole heating element thinking that was the problem. Turned out to be a $17 fuse and problem solved. Hope this helps.
Oct 07, 2007 | LG DLE2514 Electric Dryer
Dryers Logo
270 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
