Question about Building Materials
Trying to locate Old Genie garage opener model 200 manual on Internet for part numbers ...
My Genie garage opener model 200... Chain continues to run, door doesn't open..(it's unlocked, plugged in and getting electricity, checked top of unit and chain on tract there and seems elsewhere with proper tension throughout assembly), when door didn't open I released emergency metal grip handle (no red cord) and now notice that a plastic chain guide that the grip handle's long screw/spike looking end fits into is broke and the screw/ spike end grip handle won't push back up into place... So, looking for a black plastic chain guide and info on how the screw/spike end of emer pull (which fits into the chain guide) part and instructions on how to get the emer pull pushed back into place. :) Kitty
SOURCE: Chamberlan 1/2 hp security + not working
all three remotes quit working at the same time, have tried to hold the button for 30 sec. and the remote for 30 sec. nothing works.
the electric on the wall works fine,
the batteries are new in the remotes
what do you suggest, help
Posted on Dec 25, 2008
  • 1214 Answers
SOURCE: Where is the emergency release on Sears Craftsman Garage Door?
You can find exploded views and parts lists of the opener at SearsPartsDirect.com
I just checked.
Posted on Feb 13, 2009
  • 4 Answers
SOURCE: Sharp Microwave model R-1850A door won't open
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
Posted on May 10, 2009
  • 4 Answers
SOURCE: Repalce Door handle on GE Profile model number SCA1000DBB03
There're some half a dozen or so small screws securing that frame to the door face. These screws must be removed. Then, the frame can be pried out by releasing the plastic snappers (with a flat screwdriver) while in the same time gently helping the frame to detach from these snappers' hold and the door face. It's a tidious, somewhat annoying task. The snappers may and will even likely break in the process, but aren't needed for the frame to be resecured to the door face after the handle is replaced. Note that the broken ends of the handle must be held with a pair of pliers or a flat screwdriver needs to be inserted bewteen each of them and the hole, or the ends will turn with the screws. This is because the metal screws' grip of the plastic handle broken ends is very strong and will otherwise won't get separated.Once the above is accomplished, reassembling the door is a brease.
P.S.: The dual end latch may interfere somewhat with the job and can be removed for the prtocess to be undertaken without it disturbing. It's easy to remove and replace that latch, including its spring.
Posted on May 12, 2009
swolfinor
  • 504 Answers
SOURCE: Stanley garage door opener chain screw adjustment
THE ADJUSTMENT IS SUPPOSED TO HAVE A 2ND NUT THE TWO TIGHTEN AGAINST EACH OTHER AND ACT LIKE A LOCK
Posted on May 26, 2010
How do I stop my craftsman garage door opener from whining? it whines on the inside of the motor
is it gear or chain, is it genie or liftmaster. check for smooth operation of door by disconnecting motor. check tightness of cable/chain running down rail. this may be putting undue stress on gears and ruining plastic drive gear.
Oct 20, 2014 | Building Materials
Electric motor hums but does not open or close garage door
If it just hums and not actually run. Then the trolley is jammed against one of the stop bolts.
Mar 26, 2014 | Building Materials
Genie 1024 remote programming
On model 1024 genie garage door the carriage trolley jumping out of the chain what should i do to fix it or replace parts...
Feb 19, 2014 | Genie Company Genie Intellicode GITR-3...
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Can Genie Wireless Keypad work for door w/o LEARN button?
If the keypad doesn't have dip switches it will not work with that opener.
Jun 29, 2012 | Sears Craftsman LiftMaster Chamberlain...
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
Genie garage door openner won't stop when it goes down or up
there should be a "travel distance" adjustment screw on the opener.
Apr 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
52 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
