Question about Kitchen Appliances - Others
I have not received my deep copper pan - Kitchen Appliances - Others
I just got a used deep freeze.. but i was told something was wrong with the copper tubing.. it needs to be replaced.. what does this copper tube do? and relatively how much could it cost?
if the copper tube needs to be replaced then that means it is now worth fixing. the copper tube is what the refrigerant runs through. no copper tube - no refrigeration. Also you would have to fully destroy the fridge to get to the tube anyway. You may as well get rid of it. sorry
koolman77 (refrigeration technician)
Feb 07, 2011 | Refrigerators
Do i have a shallow or deep transmission pan
all 4L60e have a deep pan after 1997 or so. but not all deep pans are the same.
Sep 30, 2010 | 2003 GMC Envoy
Is my transmission pan a shollow or deep pan I have a1998 4x4
Tranny pan is the shallow pan under tranny. Oil pan is the big deep pan under the engine block
Jul 02, 2010 | 1998 GMC Blazer
How will i know if my ford explorer has a deep or shallow transmission pan
If it is a two wheel drive,most likely has shallow pan has the deep pan.But measure the deepness of the pan.Put the ruler beside the one of the bolts on the pan.If it is over 2 and 1/4 inch deep,it is the deep pan.Hope fully this will help.
Oct 09, 2009 | 1998 Ford Explorer
1998 Blazer Transmission Pan Depth
If the pan is flat all the across it is a regular pan. If it has a step near the back edge and a circular indentation in a front corner (may have a drain plug in it) then it is a deep pan!
Apr 02, 2009 | 1998 Chevrolet Blazer
TRANSMISSION OIL PAN
the depth of the tranny pan isn't really important. if you want to check the fluid let the vehicle idle and check it while its running unless its manual than you'll have to do it from underneath
Feb 17, 2009 | GMC Jimmy Cars & Trucks
Up right Amana Deep Freezer
Try taking a small piece of solid copper wire strand, loop over defrost heater and extend into drain hole, this is a trick we use to help with this issue by bringing a little heat around the hole. The freezer may be manufactured by Woods Inc, a canadian appliance builder. These did have lots of problems with the water building up between the inner and outer liners, Not much you can do with these either to totally resolve this issue. Make sure the water is going into the drain pan when you pour the hot water.
Jan 01, 2008 | Freezers
Kitchen Appliances - Others Logo
64 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
