I have a tf-t6211hdpvr and when it is hooked up it is making the tv loose channels i have changed the aerial cable and it still does it and when it comes on to record something the tv looses channels
ScottSwan
  • 33 Answers
SOURCE: No channels?
Try going into the setup menu and make sure the ANT input is set to cable. Then look for Auto Program or Channel Setup and let it scan and find all the channels it can receive. After it's done you should be able to go up and down through the channels.
Posted on Feb 16, 2008
  • 280 Answers
SOURCE: Sanyo tv making high pitch noise from loose cable connector
The noise is coming from the fly-back transformer. By moving the cable connector you move the main board. Unplug the TV and remove the back. The transformer has a red wire going to a rubber cup at the top of the picture tube. Looking at the transformer you will see a dough nut shape with a metal piece going through it .. Drive some tooth picks between the dough nut and the metal core. That should reduce or stop the ringing.
Posted on Apr 21, 2008
  • 4 Answers
SOURCE: I have an old sanyo vwm 710 vcr. I have a new
Have you tried pressing the INPUT button on the remote; try pressing it up to 3 different times because I believe it sequences 2 or 3 times. With mine, hooked up to my RCA TV, 1st push puts it in Line1 on a blank blue screen, 2nd push shows Line 2 on a blank blue screen, and 3rd push brings it back to my TV with my satellite picture showing.
Sincerely, Rick
Posted on Feb 26, 2009
SOURCE: loose cable connection plug
If the coax input on the tv is loose your never going to get a good connection because its barely recieving the signal. If the coax input on the tv is strong and does not move back and forth even a little then its probably the cable box if not hooked up to a cable box then call the cable company and they need to figure out why your not getting strong enough of a signal.
Posted on Apr 25, 2009
MNfisherman
  • 11896 Answers
SOURCE: tv only gets lower channels
Go to settings manual, go to tuner mode, select CATV, than do an auto-programming or auto channel scan and you will be set.
Make sure it is not set to AIR
Posted on May 10, 2009
I house sit a lot and every time I come back home I loose channels like four and get additional Spanish channels. I think my remote needs to be reprogramed so that I can get more local channels. The...
you have not said what tv you are using model number have you checked the cable for the aerial. if you have a booster for the aerial you can get a back feed. that would make tv say you have low signal.if you get a low signal the tv can remove channels that are to low and it would need them to be rest. digital signal need a good bite rate to be readed by the tv freeview system board.
Oct 02, 2013 | Toshiba Televison & Video
Will not connect to tv channel
  • Connect the existing Aerial/Cable TV
    signal (or from the Cable Box/Satellite
    Receiver {RF OUT or TO TV}) to the
    ANTENNA-IN socket on the
    recorder.
  • Use the supplied RF coaxial cable to
connect TV-OUT socket on the
recorder to the aerial input socket on
your TV (VHF/UHF RF IN).
Helpful Hint:
- Depending on how you have currently
connected your TV channel (directly from an
off-air aerial or Cable box or VCR), you will
have to disconnect some of the cables before
you make the above connection.
Feb 02, 2013 | Philips DVDR3380/05 DVD Recorder
We bought an LG flatscreen TV and a digital...
it's the aerial, tv has nothing to do with channels. it's the signal that carries the channels. i'm pretty sure if you had it hooked up to a cable box, you'll get all the channels, so i'm sure your tv is fine. i would double check on the aerial and positioning the attenna has some factor into it.
Oct 17, 2009 | Televison & Video
Tv with built-in digital tuner not receiving any channels
Is your outdoor aerial a proper freeview aerial and are you in a strong or weak signal area.You can check here:http://www.stevelarkins.freeuk.com/freeview_digital_tv.htm
Also check your connections as the coax may be shorting with the braid or a bad connection.once checked try ordinary channels on upstairs tv and if ok retune all your digital channels.
This can be due to a few problems.Firstly make sure your aerial is pointing in the right direction as beam aerials attenuate(disregard) signals which are not pointing directly at the aerial.
make sure you are using good quality 75ohm cable i.e rg6 and connections are good and not shorting out.
The length of run of the cable will also affect the signal as will any splitters or joins in the cable.
If you know the signal is good in your area then it will be down to the aerial,cable terminations ,aerial position or a combination of these.
If the signal is poor you can either...Buy a high db gain arial which will amplify the signal and or a masthead preamp which will again boost the signal.
please note that if your aerial is not pointing in the correct direction then any boosting of a bad signal i.e ghosting...will only make it worse.
try starting from aerial direction then connections then a high gain aerial and or booster.
Oct 14, 2009 | Televison & Video
Cannot even find where to plug to aerial point into the sony plasma flat panel display tv PFM-42V1
PFM-42V1 has no ability to receive channels through aerial / cable.
You can hook direct video cables from dvd player, vcr, PC etc.
Dec 07, 2008 | Sony PFM-42V1 42 in. HD-Ready Plasma...
I HAD TV ON. EVERYTHING WAS FINE. ALL OF A SUDDEN, IT BECAME SNOWY. LIKE THE CABLE WAS OUT. SO, I TRIED UNHOOKING DIGITAL CABLE BOX. AND HOOKING CABLE STRAIGHT TO THE TV. STILL, IT WOULD NOT GO ANY HIGHER...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} With the snowy problem; it does sound like aerial has disconnected. Try putting your finger over the aerial socket hole behind the TV while TV is on (using your self as an aerial). If snowy disappears then you have an aerial plug/wire disconnection problem.
Dec 06, 2008 | Televison & Video
Troble tuning in
If your recorder is hooked up after the cable box, then it can probably only receive channel 3...the set-top box does the switching, and sends everything to the TV (and recorder) on Ch. 3
Sep 25, 2007 | Samsung DVD-HR720 DVD Recorder
Sony TV KV-32v26
Do you mean basic CABLE channels or Aerial channels? If aerial, what kind of antenna are you using (you must have SOME sort of antenna... rabbit ears, set-top, etc...)?
Sep 20, 2007 | Sony KV-32V26 32" TV
Snowy picture, no reception?
Hi, Your question "Do bigger TV's need an aerial booster or something?" - No, normally it should work straight out. Boosters are used for fringe location not bigger TV. Pls a questions and some ideas: 1. "TV worked fine the night before" was it hooked up to Cable or aerial? 2. If cable, it is necessary that you change the settings of the TV from cable to STD or Air or something like that. Normally this can be done via the remote, menu, setting, set-up; 3. If aerial, you would probably need the assistance of a qualified service personnel. Apparently something got loose inside the Philips TV, not a big problem because you can still receive (BBC 1) but not the other channels, possibly a loose wiring, a disconnected connector. 4. If you feel comfortable working on it yourself, unplug the tv and the aerial, open the back and poke around. Trace from the aerial jack, the lead wires used, the connector to the main circuitry. Wiggle the wires a bit for any loose connection. 5. If #4 is not to your liking or if you do not find anything or no significant improvement after closing it up and running it again, guess you're back to #3. Hope this gives you some idea. Lots of luck and kind regards from the Philippines.
Jul 31, 2007 | Philips 32PT9005D TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
