Tablets & eReaders Logo
Annie Brown Miller Posted on Dec 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ipad turn off every 3 minutes with to do to fix it
Dale Brandt
Level 2:
Habit-Forming:
New Friend:
  • Apple Expert 83 Answers
  • Posted on Feb 07, 2019
Dale Brandt
Apple Expert
Level 2:
Habit-Forming:
New Friend:
Answers
83
Questions
Helped
37281
Points
148
Go to Settings > Display & Brightness, then select a longer screen-lock delay time .
Cannot open ipad asking for a pass code and says ipad has not been updated
You can try the default password or just remove the password. Follow below steps to do that.
Generally, the default passcode can be 1234 or 123456, and the digits rely on the blank number.
If this won't work, try below method.
When you find "iPad asking for passcode I never set", it is sensible for you to remove iPad passcode by restoring iPad with iTunes. The precondition is that you have backed up your iPad to iTunes before you forgot the passcode. Now let's begin to see how to get this work done.
1. Run the latest version of iTunes on your computer and then make sure that you do not connect your iPad with your computer.
2. For iPad with Face ID, you need to press and hold the top button or the volume button till you see the slider of power off shows up on the screen. Drag the slider from left to right to turn off your iPad. After that, plug your iPad into computer while holding the top button. You need to hold it until the recovery-mode screen appears.
For iPad with home button, you need to press and hold the slide or top button till you see the power off slider interface. Drag the slider from left to right to turn off your iPad. Afterwards, you need to insert your iPad into computer with proper USB cable while holding the home button. You need to hold the button until the recovery-mode screen displays.
3. In the interface of iTunes, you will see a dialogue for you to restore or update, you need to choose the option of "Restore" in the panel. Thus, iTunes will download program for your iPad. You need to wait for over 15 minutes until your iPad exit the recovery mode. Thus, you need to repeat steps 2-4.
4. Wait for the end of the procedure to set up and use your iPad without a passcode.
The process to remove iPad passcode via restoring iPad with iTunes is not so hard for you at all. You can give it a go to help you to pass through the passcode inquiry simply.
For more details, check: Fixed: iPad Asking for Passcode I Never Set
Cannot establish blue tooth connection to ipad
try to turn on BT on iPad while Logitech is blinking (which means it in pairing mode and can be discovered). If that doesn't help I'd suggest to remove batteries from Logitech for 3-5 minutes then put them back.
Ipad is black and wont turn on
Plug it in to a wall charger for ten minutes and try to turn it on. Maybe the ipad doesn't charge with comouter. Or reboot it by pressing home button with top right button on ioad and hold until responds. That can take a minute.
2answers
Disabled ipad 3
What wrong with your iPad 3? Maybe you can reply on the tablet replacement repair parts for iPad 3 to make your iPad return back new and health. Nowdays, there are more repair parts for fixing the unflexible and scracked.
13helpful
3answers
IPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
Forgtton unlock code on ipad2
hard reset the device
OK, you have noticed the strange behavior of your iPad / iPad 2 or even new iPad 3. It tends to freeze for about a few seconds every minute or is running too slow or something else. This is probably the best time for the hard reset of the tablet. To make things easy follow simple sequence:
  1. Make sure your iPad /iPad 2 / iPad 3 battery is charged above 20% (we would recommend at least 50 - 60 %). If you are not sure charge you tablet for at least 40 minutes.
  2. Make sure your Apple tablet is in Power On state.
  3. Watching the shining screen of iconic tablet with apps' icons on it press and hold down the Wake/Sleep and the Home buttons simultaneously, ignore the red slide "to power off", just keep both buttons holding until the Apple logo appears. This logo is the signal that the hard reset has succeeded. Be patient, some times the hard restart of iPad may take up to 10 - 15 minutes. But such a long restart is a rare case.
Be sure that hard reset retains all data and settings on iPad, it doesn't delete anything. If you want to start over and delete all personal data from iPad you should use iPad Recovery Mode.
3helpful
2answers
How do I cool down the iPad 3?
Hi datsyukiandeke,
Here are a few pointers I have for you when gaming on the new iPad:
  • Turn down your screen brightness. This is the best way for you to avoid heating issues. Your new iPad probably came out of the box with brightness turned all the way up. If you turn that down you will notice a decrease in heat immediately.
  • Use Wi-Fi instead of 4G LTE whenever possible. Now obviously you can't do this everywhere, but whenever possible you should access the internet via Wi-Fi and avoid riding your 4G LTE chip. That baby is power hungry and will heat up quick.
  • Give your A5X chip a break. In less technical terms, try not to play graphics heavy games (like Infinity Blade) for an extended period of time. Like you said in your question, that's when you experience the most heat discomfort. If it is at all possible for you to take even a short break (like 10 minutes every hour) from gaming, it should do a lot to keep the heat down.
I hope that helps you out!
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
