Question about Pix Cameras
On/off switch onFine Pix s4250WM - Pix Cameras
I need a manual for the s4250wm
You can find the manual here: http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s4200-s4500_manual_en.pdf
Dec 29, 2016 | Cameras
Model s4250wm. how can I turn off time stamp?
This will be a setting in one of the myriad menu modes, but details will be in the manual.
Jan 14, 2016 | FUJIFILM Cameras
Fuji fine pix s4250wm...says there is an obstruction on the lens.take cover off and try again.
The camera is sensing a lens problem. it will have to be sent in for repair.
Jun 14, 2014 | Fuji Cameras
Can not take pics/video or zoom in and out on my s4250wm
When an error is reported, with an exclamation mark, it means the camera has a malfunction. You should contact a fuji dealer.
Before you do that, you could try to remove the battery, (make sure it is charged) then after a minute or so, replace the battery and again switch on the camera.
While the battery is out, you can check the contacts, both in the camera and on the battery. Also make sure the contacts on the memory card are clean and shiny.
The removing and inserting the battery, is equivalent to cold boot of a computer.
Mar 13, 2014 | Cameras
No internet linksys connected to catalyst 2900 XL
check the vlan settings of the port on the switch to where the AP is connected, and check the vlan of the AP
Sep 13, 2009 | Cisco Catalyst 2908 (WS-C2908-XL)...
How on Earth do I reset my Pac-Pix game?
This should do it. Switch your Nintendo DS system ON and hold down the L, SELECT, X, and B Buttons before the Title Screen appears to erase all saved data.
Jun 28, 2009 | Namco Pac-Pix for DS
Toshiba 50HP66 Plasma TV
Found that video 1 and video 2 switching does not work. The switching IC was HOT!. Then found a third video input works but no sound. Hooked -up sound output of DVD player to amplified loudspkr and it works, I hate to throw away a 2 year-old plasma TV when TV and cable still works.
Thanks for the offer anyway.
Mike
Oct 12, 2008 | Toshiba 50HP66 50 in. Plasma Television
FUJI FINEPIX S7000
Try it with a different set of battery. It is possible that one of your battery is "dead" or close to it, and the camera shuts down.
You have to find the bad battery.
It worked for me.
Jan 22, 2008 | Fuji FinePix S7000 Digital Camera
ASA 5510 sec - bun k9
Basic Commands pixfirewall(config)#hostname PIX !--- Naming the PIX is optional. PIX(config)#nameif ethernet2 fo security20 !--- Naming the interface is optional. It is recommended that you !--- hardcode the speed/duplex. PIX(config)#interface ethernet2 100full !--- Bring up the interface. PIX(config)#ip address fo 192.168.1.1 255.255.255.0 !--- Assign an IP address. Failover Commands PIX(config)#failover ip address fo 192.168.1.2 !--- IP address for the failover link. PIX(config)#failover lan unit primary !--- This unit is primary . PIX(config)#failover lan interface fo !--- The 'fo' interface is used for LAN failover. PIX(config)#failover lan key cisco !--- The Pre-shared key. PIX(config)#failover lan enable !--- Enables failover. PIX(config)#failover !--- Start the failover process. This message appears on the console:
LAN-based Failover: trying to contact peer failover_01.gifLAN-based Failover: Send hello msg and start failover monitoring
Nov 27, 2007 | Cisco ASA 5510 Firewall
Cameras Logo
Top Pix Cameras Experts
Andrew Taylor
Andrew Taylor
Jay Plesset
Are you a Pix Camera Expert? Answer questions, earn points and help others
