Question about Kenmore Refrigerators
Why is there no power to my ice maker
Kenmore elite french door bottom freezer, in door ice maker will not turn on when power switch is turned on
aborcass
  • 2651 Answers
SOURCE: Amana French Door Bottom Freezer
see if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
Posted on Mar 12, 2008
  • 4 Answers
SOURCE: Kenmore elite french door freezer on bottom
Odds are due to the fact the ice maker was left on for an extended time with a full tray of ice the mechanisms froze. You can take a hand held hair dryer and defrost the parts, just be careful not to get too over zealous and melt the plastic parts. It should only take a few minutes to defrost.
To avoid this problem from occurring again, I turn the ice maker off when the ice tray is full.
Regards,
Ann
Posted on Nov 22, 2008
  • 3600 Answers
SOURCE: kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Posted on Jun 18, 2009
  • 4793 Answers
SOURCE: Kenmore Elite, Bottom Freezer. Ice maker quit
try a full unit defrost clean out vents/drains.
Posted on Feb 22, 2010
  • 1891 Answers
SOURCE: I just got a new kenmore elite 28cube bottom
NONE / unless the use of water is greater than the supply and what will hapen is the pressure will be to low to close the wate valve and a flood is possible . i used this system on my amana for years without any problems . it may not ever happen but it could . most mfg do not like this hook up . / hope this helped mm
Posted on Oct 22, 2010
Icemaker and water spout in door not working
Probable inlet water solenoid valve failure. This solenoid valve is located on the back of the unit and attached to the water supply line from your house.
Jan 26, 2015 | Kenmore Elite 78722 78729 Bottom Freezer...
How do I find out the model number of my Kenmore elite Fridge
Since the freezer is icing up there could be many different problems a blockage or a problem with the defrost or timer of the unit if u greeting unit number is should be on inside of the door or back by the condenser best bet from what I see is get a tech to fix it they will find all those numbers that u need
Dec 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Lights would not go off on my Kenmore Elite model #79577253601. light housing melted. Replaced housing and lights and again will not go off.
The door switch controls the light, and it should turn off power when the switch is depressed by the door. If it does not, it needs to be replaced.
Aug 31, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite fridge, french doors, bottom freezer: water does not come out cold. What should the temperature settings be at (for fridge and freezer)?
Fridge 34-38 degres
Freezer below 29
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker in Maytag French Door not working
replace the ice maker if the reset button has not done any good
Sep 16, 2009 | Maytag 25 Cu. Ft. French Door Bottom...
Kenmore elite bottom freezer icing up
Jun 18, 2009 | Zanussi ZEBF250W Bottom Freezer...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore freezer on the bottom. Ice-maker switch is turned on but no ice is being made?
Check your incoming water line for kinks. Make sure the water valve is turned on.
Replace the water filter.
Check inside the freezer and make sure the ice maker power cord is plugged in.
Mar 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Regards,
Ann
Nov 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
29 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
