Question about Creative Technology 101 Lessons: Vocabulary Words in Context Book Gr. 6-8 by Teacher Created Resources for DS
The opposite of need - Creative Technology 101 Lessons: Vocabulary Words in Context Book Gr. 6-8 by Teacher Created Resources for DS
What is the opposite of zero
Usually that is one.....computers use 01 binary codes....not sure really if there is an opposite to it.......like asking what the opposite to red is.
Jan 06, 2017 | Cars & Trucks
Can I reverse the door?
Janet,
Most of the time you can. If you look on top of you refrigerator, and you see some button covers on the side opposite from your hinge, you should be able to reverse the door. Second, open the doors and see if there are button covers on the face of the door frame opposite the hinge. If you have both, you should be able to change them. You usually will need a Phillips screwdriver, a flat blade screwdriver and usually a 3/8" socket or nut driver. Start with the freezer door and take the hinge loose on top and swing the door open and lift up on it and remove it. Next take the middle hinge loose so that the top of the refrigerator door is loose and you can then lift up on it and remove it. Take the grill off of the bottom front of your refrigerator and you will see where the bottom hinge is located. Remove the hinge and move it to the opposite side and then loosen the swivel pin and move it to the opposite hole and re-tighten. On the middle hinge you will need to turn it over from the direction it was originally mounted so that you can re-install it. You will also need to switch some pieces on the bottom of each door to the opposite sides so that each door will operate properly. Once all pieces are switched, including the handles, just re-assemble in reverse order that you took it apart. Hope this helps!
Jul 09, 2015 | Refrigerators
In gear but wont move
The opposite wheel should turn the opposite way.
Sounds like a part broke inside the trans.
Feb 18, 2014 | Chrysler Sebring Cars & Trucks
I dont know what the opposite of a rational number
The opposite of any number (be it integer, rational, or real) is the same number preceded by the negative sign.
Example : the opposite of a is -a (read it a negative a)
opposite of (-b) is -(-b)=b
A rational number is a number that can be written as a fraction. You should note that the set of rational numbers contains the set of all integers .
The opposite of 15/37 is -(15/37) which is equivalent to (-15)/37 and 15/(-37).
Jan 15, 2014 | Computers & Internet
I dont know the opposite of a rational number
My garmin nuvi 1300 only takes me in streets and I want to used only fwys how do I fixe my garmin
You need to get in to your settings on your unit. Change your setting from the opposite of what you have it. Im assuming you have it set at shortest distance, change it to the opposite fastest distance (or way) just change it to the opposite of what you have it set at now and will take you on expressways before it puts you on the streets.
I hope this helps you out if it does please leave me some feedback.
Apr 03, 2011 | GPS
AB is a line 652 feet long on one bank of a stream, and C is a point on the opposite bank. A = 53° 18', and B = 48° 36'. Find the width of the stream from C to AB.
The answer depends whether C is directly opposite from A, or directly opposite from B, or is directly opposite from the mid-point from AB.
Oct 07, 2010 | Microsoft Windows Vista Home Premium...
Find mii
my daughter8 says you need to look round the crowd and find someone with similar face but maybe opposite hair colour skin colour or shirt colour.
Dec 09, 2008 | Nintendo Wii Play for Wii
Trigonometric function
The 3 trig functions most commonly
used in triangle calculations are
sine = Opposite/Hypotenuse Co secant = Hypotenuse/Opposite
Cosine = Adjacent/Hypotenuse The reciprocals are Secant = Hypotenuse/Adjacent
Tangent = Opposite/ Adjacent Cotangent = Adjacent/Opposite
Hope this helps Loringh
Oct 12, 2008 | Measuring Tools & Sensors
Creative Technology 101 Lessons: Vocabulary Words in Context Book Gr. 6-8 by Teacher Created Resources for DS Logo
42 people viewed this question
Top Creative Technology Video Game Consoles & Games Experts
James Wishart
Are you a Creative Technology Video Game Console and Game Expert? Answer questions, earn points and help others
