Question about Thermador Ovens
I have a Thermador oven model x302xp which is about 17 years old now, the outer door glass is broken but I can't find a replacement anywhere.
grandadfixer
  • 99 Answers
SOURCE: outer door glass (black) for hotpoint MAIN oven model ew83k and associated seals
possibly can get it need exact model no.
Posted on Oct 11, 2008
kachbibi1
  • 979 Answers
SOURCE: oven door
Contact your nearest appliance store. Most have GE parts in stock. This may be more available than you think. I have seen someone take tempered glass and literally glue it with special heat resistant glue and it looked really pretty nice. The edges were beveled and not sharp. This of course is a last resort.
Posted on Feb 06, 2009
SOURCE: Broken outer panel of glass on cooker door
I found a replacement for my oven on ebay. Be careful, though, because one seller offered one that was the wrong size.
Posted on Jun 02, 2009
  • 512 Answers
SOURCE: St George Oven Door - Glass Broken
http://www.sga.com.au/User-Manuals/default.aspx
Anyway that will get you to the right people.
Posted on Sep 20, 2009
  • 4 Answers
SOURCE: Remove Outer Glass Of Oven Door
On my Zanussi ZDF 866 it goes like this:-
Rest the door with its top edge on your work surface. Once the bottom two screws are removed, pull the outer glass away from the bottom edge of the door just enough so that the brackets fixed to the outer glass (into which those two screws went) clear the bottom edge of the door. Then pull the outer glass up towards you parallel to the door (there are now screws hoplding the top edge on this model).
It may need one side to be pulled and then the other to release it from the metal slot at the bottom.
I would recommend great care with this given that a) your door may be different, b) it could be held more tightly and c) you are dealing with glass. Recommend taking all precautions including eye protection and suitable gloves. Proceed slowly and carefully (this did not need much force on my door). If you're not sure at any stage, choose discretion and either give up or pay someone to do the job to avoid paying for a new glass or hurting yourself.
Hope this may help someone.
Posted on Jan 16, 2010
I have a thermador oven x302xp getting code f33 on displ;ay
oven over temperature. replace oven sensor, replace relay board if repeats.
Dec 15, 2013 | Thermador C301U Electric Single Oven
I have broken the outer glass on one of the doors on a thermador SC302TB oven. Is replacing the glass something that a handy homeowner could do?
Yes. replacing the over door glass is no more difficult than removing a few screws, inserting the new glass and reattaching the screws.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232432&diagram_id=194162#d194162
That link will take you to a detailed image of the door as well as where you can order a replacement.
Hope this helps.
Sep 06, 2011 | Thermador SC302T Electric Double Oven
The glass outer glass on my oven window broke can it be repaired? It's a Thermador Model# CT227NPRS Serial# 98020093
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 05, 2011 | Ovens
Top oven glass in door is broken (thermadore).
Your oven model number is usually located on the rim of one of the oven doors or on the frame oaround a door. Some ranges with bottom drawers have the model number on the frame behind the drawer.
Here is a tip that I wrote about replaceing your glass....
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
heatman101
Mar 31, 2010 | Thermador C302U Electric Double Oven
Reassembling thermador Thermatronic II lower oven door cmt21
you can use some of the glass of the old oven just need the size of the glass if you order from the manufacturing it very exp
Jan 03, 2010 | Thermador SMW272 Electric Double Oven
Apr 01, 2009 | Ovens
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Thermador oven parts
I have a Thermador oven where the inside window glass is broken. Are there any parts available for a
model #14-33-754
30 "?
kellythompson@frontiernet.net
Oct 23, 2008 | Thermador Ovens
Cooker
HI THERE SKI IS THE GLASS DOOR PANEL THE INSIDE DOOR GLASS OR THE OUTER DOOR GLASS PANEL AND IS IT THE MAIN OR TOP OVEN.
THE GLASS PANELS INTERNALLY ARE HEAT BONDED IN THE FACTORY AND CANNOT BE REPAIRED YOU WILL NEED A NEW DOOR GLASS.
IF INTERNAL ONE COME AWAY THEN U WILL HAVE TO HAVE A COMPLETE INNER PANEL.
Feb 13, 2008 | Ovens
Ovens Logo
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
