Question about Winter Sports
Have a 1999 snowmobile polaris 500 classic.will not fire.plugs are wet.tried removing fuel from cylinders with plugs out.reinstall plugs turn key turns over will not start
  • 682 Answers
Did you try laying the plugs on the head and plug them into the wires, then crank it over and see if the plugs spark then. If they don't then maybe crank sensor or cdi box is bad.
Posted on Jan 03, 2017
2002 Polaris classic touring 500 how does fuel get from tank to carbs
please refer this manual to have deep understanding http://polaris-snowmobile.brssm.com/
Dec 27, 2016 | ATVs
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ...
www.hardcoresledder.com > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from www.hardcoresledder.com
1995 Indy 500 EFI - won't start - Polaris Files
www.polarisfiles.com > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Oct 25, 2015 | Winter Sports
2005 polaris 550 classic left cylinder not firing
Hopefully it's just the spark plug, take it out and check the gap and coloring, clean it and set the gap to the recommended gap, Or take note of the spark plug code and get a new one, check with the manufacturer or in your handbook that it is in fact the correct one.
Check the connections and lead, they do deteriorate over time, to find out if your on the right track, swap the leads over and see if the other cylinder dose the same thing. Swap the spark plug over from the other cylinder for process of elimination. So if it's still missing we know to check the pickups or cdi unit, there's a possibility its fuel, check the carburetor, is it a twin carb? If so, clean it buy taking the bowl of and draining out the fuel, you should do this occasionally anyway. Check the fuel filter while you're at it.
Good luck
Feb 10, 2014 | Polaris 2005 Classic 550
I have a 1995 polaris 600 triple it fires but does not want to keep running seems like not getting gas it will fire on full choke off it wont even fire
CHECK THE COMPRESSION OF THE ENGINE, IF IT IS AT ABOUT 120PSI AND DOES NOT HAVE A DIFFERENCE BETWEEN CYLINDERS OF 15% THAN CHECK YOUR FUEL PUMP. YOU DO THIS BY REMOVING THE SPARK PLUGS AND FUEL LINES TO YOUR CARBS AND PULLING IT OVER. IF FUEL COMES OUT OF YOUR LINES THAN THE FUEL PUMP IS GOOD. THAN I WOULD CHECK YOUR CRANK SEALS FOR LEAKING
Dec 24, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 1992 polaris indy 500 efi snowmobile and I just put a new piston cylinder head on it and got ot to run but however it will run and take off accept when the throttle is wide open it dies and I have...
hi ,i have a small and big project ,just busted a piston in my 500 piolaris indy snowmobile & to it apart & forgot about the presstone and it's all at the bottom of my engine ,where do i go from here &&&& another thing i had to drive awhile with the busted piston so what would be the damge ,what should i do with the whole thing
Jan 17, 2010 | Polaris New Genuine Polaris Snowmobile...
My indy 500 wont start i changed the fuel pump and it will turn over with stater fluied got compresion and spark
i have trouble starting a polaris indy 500 1990 new gasgets, pistons rings all i does is back fire through the two carbs
Dec 11, 2009 | Polaris New Genuine Polaris Snowmobile...
Indy 500 motor knocks
could be bad gas. try running fresh gas. if that dont work you have internal problems. make sure it is firing on both cylinders though. when you start it cold you can feel if one is running hotter than the other. do a compression test. 120 psi is normal and no more than 10 lbs difference between cylinders. if one is low motor needs a rebuild
Jan 20, 2009 | Polaris New Genuine Polaris Snowmobile...
Winter Sports Logo
831 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
