If I do not attach the "dock" to my wall do I need to keep the motor unit plugged in to constantly charge?
  • Audio Player... Master
  • 16,185 Answers
Yes you do.
Posted on Dec 29, 2016
My power cord for the docking station is beginning to unravel with wires showing. Can it be replaced or repaired?
First, I know nothing at all about ipods. However, I am a decent electronics guy. Obviously, one end of the power cord plugs into a wall outlet; the other connects to the station. How? Does the cord simply disappear inside the station, or is there some kind of connecting plug? Which end is frayed? If it's at the wall plug end, you could simply cut the wire (unplug it first !!!) above the fray and wire in a new standard wall plug. You can do the same on the station end if the wire runs directly into the unit AND if you can get in there to reconnect the wire. If, on the other hand, the wire is attached to the station via some sort of power plug (like a printer for example), you'd better leave that puppy alone and invest in a new docking station or new power cord. You'd also better stop using the unit unless you can fix it. Bare wires spell tripped breakers and danger of injury.
May 28, 2016 | JBL ONSTAGE Docking Station for iPod
Why does battery beep and tells me its on battery power when it's stil plugged to wall. and i have a good power source
Usually that indicates a low battery charge or bad battery. Make sure you do not have the battery backup side overloaded with too many devices. Do not plug inductive loads with motors or heating elements into the backup. Turn the device off and unplug anything that is plugged into the bachup. Plug the battery backup into the wall with nothing attached and turn on. Wait 10-15 minutes. this will charge the battery. If beeping continues after this with nothing attached, you likely need a new battery or the control/monitoring system is bad. If beeps stop, reinstall and do not attach more wattage than the unit can suppluy
Jan 06, 2011 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
The unit suddenly stopped working; contact is plugged in but on-button does not work. No lights on, it does not seem the unit has power.
I faced a similar problem with Mine a couple of days ago.
Try these below
1. Keep the unit plugged to the wall socket (and charge). Green light (indicating charging) may not glow. It doesnt matter. Keep it on for a few hours.
2. Then try to turn on the unit.
3. If it still doesnt turn on, fold the unit and keep it aside for a few mins (say 10 mins).
4. Open it and then try to turn it on.
Mine worked with step 4.
See if this helps.
regards,
Lakshmi
Nov 21, 2010 | Altec Lansing Inmotion-IM600...
Samsung A767 constantly needs charging. Why does
it happened to my fone too but i then i just had to put it into a new plug place...or you need to replace your charger dock thing
Feb 13, 2010 | Samsung Propel A767 Cell Phone
How do I charge my new iphone 16GB?
Your new iPhone comes with a USB cable and a wall charger in the box. If you don't have a computer, you can plug the wall charger to any socket in your house and connect your iPhone to the wall charger using the USB cable. However, if you have a computer, you can plug the USB cable to any USB slot from your computer and connect it to your iPhone.
You can also charge your device from any iPhone dock, or even those docks attached to your home theater system.
For more iPhone / iPod touch tips, click here.
Feb 12, 2010 | Apple iPhone (16 GB) Smartphone
I have a T2+ remote sys and need a manual. as a start I need to know how to charge.
The remote comes with a charging dock, if you did not get this you can order one from RTI (952) 253-3136.
BATTERY AND DOCKING STATION
The T2+ uses a Lithium-Ion rechargeable battery. This battery does not exhibit any type of "Memory Effect" from being charged too often. Since the T2+ can safely be charged after each use, a docking station is included for convenience. If left out of the docking station, the T2+ will remain in sleep mode for 1 or 2 months before shutting down. At that point the battery must be recharged. The T2+ Docking Station can be placed on a flat surface such as a shelf or table, or it can be mounted to a wall using the mounting holes on the back of the unit. If the T2+ battery capacity is reduced to approximately one hour of remaining run-time, a low battery icon will appear in the upper left corner of the display The docking station LED illuminates to indicate a charge in progress. The LED will turn off when the battery in the unit is fully charged.A fully discharged battery will take approximately 2-4 hours to completely re-charge.The T2+ can remain in the docking station indefinitely without damage to the battery.
Jan 17, 2010 | Rti Technologies Rti T1 Remote Control
Battery in im600 not charging
The battery is probably dead, as it's rated for 400 cycles. When you have the dock's feet out, you can see 2 tiny screws on the back of the unit, unscrew them, remove the hatch and you'll have your battery exposed. 3.7V 1800mAh Li-Ion
Mar 09, 2009 | Altec Lansing Inmotion-IM600...
Philips dock & play#dc199b-can it charge and play 4th.gen.ipod
yes just eject it from the computer and it will keep charging and if you have on that plugs into the wall then just unlock it and click the center button!!!!
Jan 23, 2009 | Philips DC199B/37 iPod Docking Audio 2.1...
Antenna not detected
Try docking the unit without the battery attached. The unit will recycle and that may solve the problem. You will, however, need to continue to dock the unit without the battery...
Dec 08, 2008 | Sirius STILETTO 100 MP3 Player
Dock Connector Charging Problem
I had that problem one time and the only way to get rid of that icon was to plug it into my Bose sound dock. You could also try another brand of sound dock to see if it works. Good luck
Nov 11, 2007 | Audio Players & Recorders
 Grubhead
Grubhead
