Question about Sewing Machines
How do I sew monograms with the middle initial larger than the side initials?
Tension on upper thread not right, thread keeps snapping
Most likely, your tension is too tight. First thing, unthread the machine. RAISE the presser foot and rethread from the beginning. The standard initial tension setting is the midway point between high & low number, HOWEVER, that will probably need to be tweaked as machines vary.
The tension is correct when upper and bobbin threads meet in the middle of the fabric. If the thread continues to break, then there may be a snag somewhere that is catching the thread and breaking it. Also, check that the thread notch on the spool is not catching the thread. Be sure your needle is compatible with the thread, ie the thread is too thick for the needle eye.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
How to Adjust Sewing Machine Tension on Craftsy
Dec 09, 2016 | Sewing Machines
Singer Futura3 software load keep getting Failed to initialize security
contact singer customer service and ask them if the software is
for windows 7 or do you need some type of patch or do you
need to use the compatibility settings?
Dec 20, 2012 | Singer CE-100 Futura Computerized Sewing...
I would like to find a machine that monograms and does not cost over $500. All I want to be able to do is the traditional 3 letter monogram (larger letter in center) or a child's name, such as Charlotte...
My advice is to try going to a shop that sells machines and gives lessons for free. I bought from JoAnn's and they gave me lessons on it. I bought a Brother for $549 and I am not sorry because I actually know how to use it thanks to the girls at JoAnn's. I would not be using all of the features if I didn't have the hands on instruction. The manual is great for a refresher but nothing beats doing it and someone answering your questions. Think about it before you buy online, you may save a few bucks but in the long run you will be happy to have a relationship with people who care if you have a problem and can help you.
Jan 02, 2011 | Brother SE-270D Computerized Sewing...
The rod connected to the needle is not moving up and down anymore. I was sewing a straightline at setting 2 when the rod just stopped. We romoved the top and side pannel. Then we turned it on to see if the...
Easy fix is take to local repair person, but barring that you will need to look to replace the little knob so that it tightens down and grabs the larger knob. Sometime you'll need to try to place it on the machine a few different ways till it works right.
The little knob is used to disenage the machine for winding a bobbin. Add little bit of machine oil to help keep it loose.
Dec 17, 2010 | White Sewing 1766 Mechanical Sewing...
I have a CE-4000 model. In the middle of sewing,
When you put back in the bobbin case, there is a little "knub" that sticks out with a flat spot on the right (on the top side of it) that you need to ensure it rests gently to the left of the position finger bracket (silver metal piece, in the square of the bobbin case area its on the right closest to you).
When you put in initially, it was probably twisted clockwise and there was a gap between the knub and the position finger bracket and when you put the needle plate on in jams that bobbin case in that position and the needle just takes chunks out of it..
You might need a new bobbin case, try sanding out the needle marks with sandpaper.
Jun 04, 2010 | Brother CS-100-T Computerized Sewing...
How do i get rid of short of memory space the filecannot be saved on the usb stick on a janome 350e thank you
before you can add more to that memory stick you must first delete something else ...if everything you have on that memory stick is important to you and you dont want to erase anything then you can get another perhaps larger memory stick .. they are normally not expensive .. if nothing is important on that stick then you can reformat (initialize) it .. that will erase everything and you will be starting over with a fresh memory ..
Jan 05, 2010 | Sewing Machines
Futura CE-200 Software fails to initialize on XP sp2
Maybe you should try to contact singer south africa and ask them whats wrong, my laptop did the excact same thing switch over to home pc and no problem ever again.
Mar 02, 2009 | Singer CE-200 Quantum Futura Computerized...
Bernina deco 600
Sorry to inform you but your machine only sews 4" x 4" . The arm on the machine can only move 4 inches up and down and 4 inches left and right.
The size of the hoop does not affect this. If you have a multi position hoop you can sew multi 4 x 4 areas without re hooping.
Feb 28, 2008 | Bernina Bernette Deco 600
Monogram larger
the two sizes of monograms letters are upper and lower case
Feb 21, 2008 | Kenmore 19606 Computerized Sewing Machine
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
