Question about Cell Phones
Why does the main slider not work properly as it should do as the bed slider works well
Are there different types of tanning beds for use at home?
There are basically 2 main types of tanning beds for home use. The first one is the most common type - which is the horizontal bed or the capsule. Less known is the stand-up vertical chamber. Both types work on the same principle of emiting UV rays to mimic the sun
Feb 18, 2013 | Health & Beauty
What is a loft bed?
A loft bed looks very similar to a bunk bed. Likebunk bed, it also has two stories, main difference being that the lower sectionis usually used for non-sleeping purposes such as computer and office work. Thistype of bed is very common among students.
Jul 30, 2012 | Furniture
What is a loft bed?
I CAN SEE CALLERS VIDEO BUT THE CALLER CAN'T
I think that The secondary camera (front camera) of your phone is not working properly.Open camera and check the secondary camera by pressing option (use secondary camera)if it is not working you need to change the main flex(strip/pate) with good quality.on the other if it is ok first check by moving the Slider 2-3 times.Still its not working just make a comment below........
Jul 09, 2011 | Nokia 6500 Slide Cellular Phone
My pmp6000 wont work in mon1/ mono mode. I have one speskon channel going to two mains and the other to two monitors Can't get sound.
OK... from the schematics it appears that when in mon1/mono mode you use ONLY the MON1 gain controls, including the channel MON1's and the MON1 slider. Make sure you have each of those turned up as needed. In this mode, MON2,s and the MON2 slider are unused. The MONO slider controls the MAIN output.
Dec 03, 2010 | Behringer Europower Pmp5000 Powered Mixer...
I have this mixwer for domestic use only, swithced it on last night and power is there, but no sound at all, from any channel.Could you please advise,
Make sure your audio source is playing.
Make sure your channel is not muted.
Make sure your channel is assigned to "main mix" (bottom button to right of main volume slider).
Make sure your main output slider has volume applied.
Make sure the cable you're plugging into your "main output" is being plugged into the 1/4" or xlr output receptacle that corresponds with the slider you provided volume to.
You should then put the outgoing cable into either an eq or an amp.
If you're going to an amp first, place the cable carrying the signal from the board into an "incoming" slot on the amp. Run a cable from the output of that channel of the amp to a speaker. Turn on the amp and fade the volume knobs up. That should give you power - provided your board, cables, amp and speaker are working properly.
If you're going to an EQ first, place the cable carrying the signal fromt he board into an "incoming" slot on the eq. Then run a cable from the output of the same channel on the eq to an incoming slot on your amp. Then run an outgoing cable from the same channel on the amp to a speaker. Flip your eq on, flip your amp on, fade up the volume on the amp, and make sure you don't have a gate closed on the eq (also make sure if you have a gain knob on the eq, that it's at least partially providing power). If your board, cables, eq, amp and speaker are working properly, you will have sound.
Nov 18, 2010 | Yamaha Mg8-2fx 8-Channel Mixer with...
Slider part keypad not working properly, only number keypads are working
Possible that the flexible membrane strip of the connection to the slider keypad is broken off there by cutting off the connection.
These membrane strip wires must be procured to be installed back into the main board and connected to the slider pad.
Attempt only if you are experienced to do these delicate jobs.
Oct 23, 2010 | Cell Phones
Dreamland Imetec blanket.1 side controller flashes red.Swapped controllers,problem still there.Seems confined to 1 side of the bed as both controllers work fine on the 'good' side but neither work(ie. both...
I have been getting over this problem by operating the switch slider very rapidly. Sometimes it has to be done back and forwards a dozen times before the light stops flashing.
Nov 01, 2009 | Kitchen Appliances - Others
Transfer
All you have to do is remove the plastic slider rails on the top and bottom of the front rail and take off the rail. This bed still has 3 rails like a daybed when it is changed into a toddler bed.
Jun 04, 2008 | Cosco 2-in-1 Sleigh 10121 Crib
Switch is stuck in on position braun 7505
You only need an small screwdriver, pull out the blue button and the metallic part, Ready!. Only one thing, you have to forgett about the aesthetics of the shaver, but it's work perfectly, Thanks a lot!
May 30, 2008 | Health & Beauty
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
