Question about Samsung Cell Phones
How to open and replace battery on samsung level active bluetooth headset
  • Samsung Master
  • 20,369 Answers
Posted on Dec 29, 2016
Testimonial: "thanks but i am more looking for a visual or video tutorial on actual replacement."
  • Andrew Taylor
    Andrew Taylor Dec 29, 2016
    Small items like that are almost impossible to take apart. You need a set of 'budger tools', and you need to know the exact location of the plastic clips so that you don't snap them off. Then you probably need soldering skills as it won't be a standard push in battery.
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
How do you turn the samsung hm3700 bluetooth on? How do you snyc it to your phone?
To turn on the Samsung HM3700 headset, slide the power switch up. (You can see it's location on the image below). The indicator light below the power switch will blink blue 4 times (purple or red means your battery is low). If it stays blue it is ready to sync with your phone.2_29_2012_5_42_10_pm.jpgThere are 3 ways to sync this device to your phone:
  1. Once the headset is on, hold down the talk button for 3 seconds. (the blue light will stay lit for 3 minutes once you enter pairing/syncing mode).
  • Activate Bluetooth on your phone and search for the hm3700 (keep them close to each other).
  • Select the headset and enter a PIN number if asked.
2.) Active Pairing: Once you have held down the talk button for 3 seconds and the blue light is on, press and hold the talk button again to make the blue light purple.
  • The device will try to automatically connect to your phone for 20 seconds. Your phone should not be connected to other Bluetooth devices during this process.
3.) FreeSync is an application you can download if you have an Android (from the Android Marketplace). It allows you to access your headset settings and I believe it can read your text messages for you (text to speech).
For more information the user manual for your Samsung HM3700 Bluetooth headset can be found here: http://downloadcenter.samsung.com/content/UM/201111/20111116163119314/HM3700_UM_America_B_Rev.1.0_110923_screen.pdf
Feb 29, 2012 | Samsung Cell Phones
I have a Samsung Flight Phone. Model: SGH - A797. How do I connect my bluetooth to the phone?
I think this phone does not supports bluetooth it m wrong then do the following..
Connecting Bluetooth Headset to Phone First activate you Bluetooth on both phone n as well ason headset...Then search from phoneto Bluetooth headset then.....Select it n pair it to your phoneusing any passkey which should be same in both the devices..and afterpairing u can use it....nicely...
Apr 06, 2011 | Samsung SGH 2400 Cellular Phone
Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Feb 23, 2011 | Cellular Innovations HFBLUH1 Bluetooth...
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Tips & Warnings
Hope it helped.
Thanks for usingf ixya..
Jan 13, 2011 | Plantronics Explorer 320 Wireless Headset
How to use bluetooth headset in samsung corby???? plz plz help me
1. Just activate the bluetooth in your mobile.
2. Put your bluetooth headset in discovery mode (for this you may need to press the ON button in your headset for more no. of secs around 15 secs) . Please read the user manual of your bluetooth headset to know about how to put it in discovery mode.
3. After that, search for bluetooth devices in your samsung mobile.
4. your headset should be detected in your mobile. If not, still your bluetooth headset is not in discoverable mode. you have to turn it on and try again.
5. If listed in your mobile, select it and it may ask for Passcoe. Provide 0000 as passcode. Thats all now the bluetooth headset is connected to your mobile. If passcode is not accepted, then please do refer the device manual to know about that.
I hope this is useful to you.
Thanks
May 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Battery Backup of my WEP 200 Bluetooth Headset
I purchased new Samsung WEP 200 Bluetooth Headset but its Battery Backup is not even 1 minute. From where I can get the battery. I am based in Vijayawada, (A.P) (India) & what could be the approximate cost.
Oct 29, 2009 | Samsung Bluetooth?® WEP200 Headset...
Samsung WEB410 bluetooth headset won't hold charge anymore
Well if it holds no charge you will most likely have to replace it as it is the battery inside the bluetooth headset in otherwords the battery is buggered lol. do you still have the headset and the charging cradle?
Oct 15, 2008 | Samsung WEP410 Bluetooth Headset Wireless...
Pair Bluetooth Stereo
put the music player on and press down on the jogwheel, select 'Play Via' and change it to Bluetooth stereo headset. It'll prompt you to open the swivel and take you to the bluetooth devices screen where you select the correct device, it'll then prompt you to close the swivel and will start playing through your headphones :-) Is that what you mean?... It's a bit of a pain really :-(
Aug 04, 2007 | Samsung SGH-X830 Cellular Phone
Cell Phones Logo
53 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
