Question about Sharp Televison & Video
My sharp tv is frozen. It freezes at the sharp logo when I turn it on. I have unplugged it and left it unplugged but that still doesn't work. How can I fix it
  • Sharp Master
  • 6,694 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here
Posted on Dec 29, 2016
maatmartin7
  • 1213 Answers
SOURCE: We went to turn our TV on and when it turns on the
The standby power supply resistors on the inverter board have changed values. You will replace resistors R1217, (820K 1/4 watt), R1218,(820K 1/4 watt) and R1219 (390K 1/4 watt). Please use the values just mentioned. Or you may have the inverter board replaced. Take this note to a TV repair Tech.Thanks for asking and show a few hands of support!
Posted on Mar 12, 2011
walesarumi
  • 6993 Answers
SOURCE: Sharp, 20
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on Nov 10, 2011
walesarumi
  • 6993 Answers
SOURCE: Vizio E371VL doesn't turn on
I hope this helps.
Regards.
Posted on Jan 18, 2012
  • 3368 Answers
SOURCE: I have a lc60le650u sharp TV it's frozen on the start up screen that displays the word sharp in red and the only way to turn it off is to unplug it.
Sounds like time to get a service tech or a new TV
Posted on Jan 12, 2015
AJIN G
  • 6694 Answers
SOURCE: Remote and controls on side of tv dont work unplug tv and just displays sharp logo .what can be done?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Apr 16, 2016
Sharp lcd tv turning on, sharp logo comes up then it powers off
can be backlight issue. lamp defective in lcd screen. try to force on unplug tv .and then press and hold volume - channel+ and input buttons on tv while holding down these buttons then plug in in. will come on .its mean lamp defective.
Apr 25, 2017 | Sharp Televison & Video
Sharp aqous LcD TV not powering on when you turn on only Sharp red color logo appears on screen screen stays frozen on the same screen nothing happens after that
Corrupted firmware. an update might be necessary. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Dec 15, 2016 | Sharp Televison & Video
Sharp displays frozen on start up logo. Just shows SHARP and wont change sources or anything. Model # LC-65LE645U
Sounds like corrupted firmware. A firmware update might be necessary. If you wish to get some details; check the site linked here. Pull up older posts.
Bfore doing anything; try a hard reset to this set, and check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 24, 2016 | Sharp Televison & Video
When turned on, why does it just display SHARP logo?
The logo displays when you turn the tv on. You need to select a signal from one of the inputs. Pressing the input button repeatedly will cycle through the inputs. As long as one or more of them is on and broadcasting you will find a picture.
Feb 23, 2016 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
My 39 inch tcl led TV power cord got abrubtly unplugged while watching TV. Plugged it back in and now the TCL logo on the start up screen stays there frozen. Many times already tried to unplug it, wai
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again.
Sep 14, 2014 | TCL LE39FHDF3300 39" LED TV 1920x1080, 60...
Sharp copier freeze up
If its a digital printer the problem is the hard drive.
Feb 04, 2013 | Sharp Office Equipment & Supplies
Go to turn on tv and all I get is flashing red light and tv won't turn on. Was working the other day.what do I check?Sharp LC-26GA5U
Try unplugging the TV from the power point and leave unplugged for 5 min.
Or the batteries in the remote may be flat, try replacing the batteries.
If this doesn't work the TV may have a fault.
I hope this helps
MobileJB
Jul 13, 2011 | Sharp LC-26GA5U 26 in. HD-Ready LCD...
We went to turn our TV on and when it turns on the Philips logo usually appears before it turns on. It is frozen on the Philips logo screen. You can't turn it off. And it will not go to the TV. I'v...
Mar 12, 2011 | Philips 42PFL3704D LCD TV
Television displays in blue , only checked all
For your remote problem, mine has stopped working a couple of times and here is what Sharp had me do: Take the batteries out of the compartment. Next press and hold down the power button on the remote for a count of 30 seconds. Return batteries and the RC should be reset. As for the other problem, I had a similar thing happen tonight, hence I am on this site looking for help. My remote quite working, so I did the above, to no avail. I noticed the channel number box was frozen on the screen. I could not turn the TV off manually and had to unplug from AC. I plugged it back in and got sound but no picture, just that bluish dark screen. TV would not turn off. Then I got nothing, no sound, no pic. I left the TV unplugged for several minutes, 5 or so, plugged it in and it did work and is working now, RC too. You might try unplugging it for an extended time.
Jun 11, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
29 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
