The water will not go into the machine it spills out at the soap despenser
  • Washing Mach... Master
  • 5,323 Answers
SOUNDS LIKE UR DISPENSER TUBE/HOSE IS PLUGGED
Posted on Jan 06, 2017
After switchig the machine.on the desplay unit showing despensing unit blocked
Open the draw remove it from machine run it under hot water in your tub till all the soap powder is cleaned out,then refit and fill with hot water to clear pipe to drum.
Feb 02, 2017 | Washing Machines
Soap does not despense and h20 keeps coming up.
something wrong with the water inlet
perhaps the washers valves or filters
Dec 09, 2014 | Hotpoint Washing Machines
Looking at machine top left side in back leaking out of little vent
If its water you may have to lift the control housing and look underneith, there are soap despensing water valves there, thet could be leaking
Sep 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Water runs out around soap despenser
Necessary to clean the pallet of the loading the soap.
Jan 07, 2011 | Kenmore HE2 Plus Front Load Washer
Bleach despenser not working? soap and softener
Hello. Most likely your water inlet valve is the problem. If you are mechanically inclined you can change this yourself. That said, if your machine is less than two years old it is still under warranty. If so, call for service at Sears.com
Regards, Joe
Jan 16, 2010 | Kenmore 46462 Front Load Washer
The water is over flowing from the soap dispencer. i pull the tray out and the water is slowley draning into the machine how can i unclog it
it is most likely soap or softner clogging the hoses.
remove dispenser drawer (pull out to max, on the top near the rear of the dispenser there will be a tab that will allow you to remove completely) clean out anything that you see with rag, old toothbrush etc. any way you can, then put some hot (almost boiling water in the despenser area. this should clear your issue.
Oct 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water spilling
If water is spilling from the soap tray, try closing the water supply taps a little. Your water pressure may be too strong for the machine...common issue for front load machines when being used on water lines that have not been properly regulated.
Aug 05, 2009 | LG WM-2277HW Front Load Washer
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
